Author Topic: Please Suggest a Circuit to Use With a Regulated 150v PS  (Read 1761 times)
john abney
« on: July 04, 2006, 02:18:46 pm »
I have a Dressen-Barnes Regulated Supply, model 22 102 A. It's rated at 150 volts at 70 mA. There is also a 6.3 volt filament supply. The item uses five tubes.
I'd like to know if it's practical to use the power supply to run some sort of tube circuitry, such as a microphone pre-amp, an electronic crossover, or the like.
What types of circuits could benefit from having a regulated supply? And is 150 volts enough for a real circuit, or is that getting down into starved-plate land?
Your comments would be appreciated.
best,
john
some new jabney & mccarthy songs coming soon to thecodes.net
danickstr
Re: Please Suggest a Circuit to Use With a Regulated 150v PS
« Reply #1 on: July 07, 2006, 03:41:11 pm »
ask this in the tech section (or maybe STeve will move it for you) and you will get a better chance at a good answer.
Nick Dellos - MCPE
Food for thought for the future:              http://http://www.kurzweilai.net/" target="_blank">http://www.kurzweilai.net/www.physorg.com
rodabod
« Reply #2 on: July 09, 2006, 02:58:45 pm »
The power supply could run many different valve circuits probably.
I suppose it depends what you are looking for.
It may be easier to make a supply from scratch if you have a particular design in mind which requires a different HT or heater voltage.
Roddy Bell
