Pages: 1 ... 5 6 [7]   Go Down
Author Topic: Your chain  (Read 48570 times)
mastertone
Re: Your chain
« Reply #90 on: July 09, 2009, 04:15:48 pm »
Hey Jaakko, did you ditch your opto? I liked what i heard from it, very brief but still.
EDIT, sry, slow eyes, is this the one?
Before this I'll also try out an optical compressor in the chain, based on the sidechain Fred Forssell has published. I have a certain sound of compression in mind with this.
Jonas Ekstrom
Mastertone Mastering
www.mastertone.se
Viitalahde
Re: Your chain
« Reply #91 on: July 09, 2009, 04:21:51 pm »
mastertone wrote on Thu, 09 July 2009 21:15
Yeah. I gave it to the mixing guys. I just began using it less and less, and eventually stopped. Chain evolution I guess..
Jaakko Viitalähde
http://www.virtalahde.com
mastertone
Re: Your chain
« Reply #92 on: July 09, 2009, 04:25:35 pm »
Viitalahde wrote on Thu, 09 July 2009 15:21
Ok! Too much color, or not enough controls on it?
Jonas Ekstrom
www.mastertone.se
TotalSonic
Re: Your chain
« Reply #93 on: July 09, 2009, 05:50:02 pm »
Interesting to look back at my old post from 3 years ago where I was 3 months into working at my own room after an 8 month break from when Europadisk closed.
Lots of things have in fact remained the same but some things have changed.
TotalSonic wrote on Wed, 28 June 2006 04:55
Digital Source (SAWStudio DAW #1 w/ Lynx One AES outs, DA-20 or PCM2600 DATs, MD350 MD player. Denon or Philips CD players)
-> Z-sys digital patch bay
-> 2 Lavry Blue DAC's (1 direct to Coleman M3PHmkII for source monitoring, 2nd to chain) ->
OR
Analog Source (Sony/MCI JH110M / Sansui SR717 turntable / Denon cassette deck) ->
Nothing different here except the PCM2600 died and was replaced with a Panasonic SV3700 (which also goes just as unused!), and I added a Sony DVD player, a Yamaha 4-track cassette deck and a Panasonic VCR player (not that any of these have gotten much use either but I still like to be able to offer transfers from as many formats as I can).
I also recently added an Otari MX5050 to allow me to actually record to 2-track tape when desired (my MCI JH110M is a playback only deck) and to playback 1/4" 1/4 track tapes - just got the transport fixed on it but still have to get heads relapped for this one so it hasn't seen any action just yet.
I upgraded my phono pre to a Simaudio Moon LP5.3 - been really happy with this.  I've also been thinking of upgrading my turntable - have my eye on this one  - www.needledoctor.com/Pro-Ject-RM-5-Turntable
Quote:
Amek Medici eq ->
API 2500
OR pair of custom modded NTP179-120 ->
The Medici is still my primary go to eq, and the API2500 still gets plenty of work here as well - but the NTP's are out of the chain now - replaced with a Focusrite Blue 330 and a Pendulum OCL-2.
Quote:
Mytek Stereo96 ADC ->
Z-sys digital patchbay ->
SAWStudio DAW #2 (w/Sydec Mixtreme192 & ibox AES4)->
This is all the same but I stopped using the ibox AES4 to connect to the Sydec Mixtreme and replaced it with an Apogee Soundscape 896I/O as it gives a ton of connectivity into the DAW (8 channels AES, 8 channels TDIF, 8 channels ADAT, 8 channels analog i/o in case I have to do multi-channel transfers).
Quote:
RML Labs Levelizer &/OR Waves L3 ->
Both of these limiters are now almost never used - replaced by Voxengo Elephant 2 & 3, as well as occasional use of GVST GClip and Stillwell Audio Event Horizon+.  I also bought the Flux Pure Limiter II recent but haven't attempted to solve my system's severe stability problems with the full version of it yet.
Quote:
Sonoris Dither (or sometimes Waves IDR dither if the L3 is the final processor)
Using the Sonoris Dither exclusively these days.
Quote:
Of course a lot of times things aren't as "simple" in which case the above might get augmented on the analog side by:
-> pair of Filtek MKIII eq's - if I need either a hardedged bottom or more bands than the Medici gives me,
replaced by both an API 5500 and a modded Sontec MEP250EX
Quote:
and sometimes a
-> SPL Vitalizer (I have the original stereo version, the SX2) if dealing with something that has too much "M's" (i.e. Mono-ish, Muddy, Muted, overly Mid-rangey)
I had Dan Zellman swap out a number of the IC's in this for ones with lower distortion and lower self noise - definitely helped make it give cleaner results.
Quote:
& on the digital side (either patched into the playing DAW or receiving DAW depending on the processor) as needed of:
(fully automateable 64bit processing SAWStudio native plugins)
JMS Audioware Hi-res EQ
Sonoris Compressor
Sonoris Mulitband Compressor
Sonoris M/S codec
Sonoris Equalizer
Sonoris Linear Phase EQ
Sonoris Pitch/Time
Brainspawn Stereo Panner
The updated versions of Sonoris EQ & LPEQ are getting lots of work for both minor tweaks and surgical needs here - the 2.x versions of these are simply some of the best digital eq's ever made.  Been using the Flux Stereotool instead of the Brainspawn Stereo Panner these days though.  The rest of these plugins only get used rarely although occasionally I do still like the JMS Hi-res EQ in preference to my other options for creating big low shelf cuts with really high slopes in order to reshape the bottom end away from rumble and into thump.
Quote:
(DX/VST plugins)
Virtos Stereo Processor
Virtos Noise Reduction
Sony NR2.0 Click Remover
Spitfish De-esser
AIPL Warmtone (only used in rare cases to distort side channel)
Added Acon Digital Studio Clean (primarily for it's excellent declicker/decrackler), Voxengo Redunoise, and Wave Arts MR Hum to help with restoration tasks.  I also got a UAD-1 card loaded with the Precision series plugins but frankly I almost never use it beyond occasional use of the Precision De-esser (it's just it's resale value is lower than the value I get by having it listed in my gear list).
Quote:
As far as things I'd like to change in the chain:
* well, while the Filtek's usually work well as a secondary eq - I'd still like to find another option that could be a lot more subtle as the Filtek's 2dB steps tend to be overkil for most applications.
I ended up selling off my racked pair of Filtek MK3's and got a Sontec MEP250EX (modded so the pots gain ranges are half of what they are stock), and an API5500.  Both of these have a lot more headroom and versatiliy than the Filtek's although once in a blue moon I do miss the hard edged bottom the Filtek's had.  The 2dB steps with them were definitely deal killers.
Quote:
* I had Dan Zellman open up my Medici and he's pretty sure he could open up the sound a little more by upgrading the caps in it.  I'd like to replace the pots on the input gains (seems Neve doesn't see any problem with this as the same kind of thing is on the Masterpiece) with stepped switches in 1/2dB steps also.
I ended up getting these mods done (stock cheap Korean caps replaced with current Panasonics that have much better specs) and am definitely glad to have done it.
Quote:
* I'd like to get either a Weiss DS-1 or a Maselec de-esser to hopefully better handle this chore than my current in-the-box options
Didn't get either - instead I got a pair of Empirical Labs DerrEssers in an Avedis R52 rack - cheaper than either of these other options but it works fantastic to my ear for dealing with both sibilance or edgy overly bright percussive elements.
Quote:
* definitely would eventually like another dynamic processor - the DW Fearn VT7 really caught my ear recently - but I'm open to other options
Ended up getting not one but two new options (Focusrite Blue 330 and Pendulum OCL-2).  Definitely happy to have these options now as they both give very different sounds from my API2500.  The one mod I still want to do though is to get rid of the OCL-2 output pots and have these replaced with stepped switches.
Quote:
* and definitely would like to get an analog M/S matrix.  Think the Dangerous S/M box might be the ticket - but I'd be curious to see if I could just get some of the older Neumann or Telefunken "panorama" modules racked up to get the same functionality for less cash.
Ended up instead of getting a pair of ADR Propak Audiomates (now discontinued) and then had the input pots and bypassed and the opamps upgraded from the stock JRC's to NS LM's (forget the actual part #).
Quote:
* I downloaded the Voxengo Elephant 2.5 demo recently and, unlike the first version, was pretty impressed with it, so this will be my next digital processor purchase as another alternative to the other digital limiters I have
Which indeed it was.
Quote:
* I'd like to look into possible upgrades beyond the stock repro amps for my JH110B
still on the to do list.
Quote:
* and finally thinking of getting a Lavry Blue ADC module added into my 4496 box as an option to my Mytek.
Also still on the to do list.  Been thinking of Lavry Black or Burl B2 as possible options as well.
Quote:
...but at this point all these things are of lower priority than getting a few things sorted out in my monitoring  - so at this point stands for the N802's and some more treatments for the room that will be my next purchases.
Which they indeed were - both the Sound Anchor stands and tons of GIK Acoustics bass traps made a big difference in getting things sounding more accurate in here.
The biggest other change to my chain is going to happen in about a couple weeks when my Manley Backbone finally gets here.  I'm excited to finally be able to insert processors with a button instead of having to physically repatch things.
Best regards,
Steve Berson
compasspnt
Re: Your chain
« Reply #94 on: July 09, 2009, 06:01:20 pm »
Steve, a (perhaps hypothetical) question...
If you were called upon to recreate a master from two (or more) years ago, or to "just make this one little change" to such an "old" master, what would you now do?
•Drag out all the old stuff (if possible)
•Come as close as possible with your current chain
•Start over and do it "my way today"
•Other option
TotalSonic
Re: Your chain
« Reply #95 on: July 09, 2009, 06:17:50 pm »
compasspnt wrote on Thu, 09 July 2009 18:01
•Other option
Well - I still have nearly all my masters and session files (including edit list files and 24bit captures from my analog process chain) and from the past few years from the start of my own studio as digital archives.  If the archive failed or was missing and I needed to recreate  a previous master exactly due to client request my "go to" processors as well as the converters have remained the same since I opened the studio - and since I have nearly all my recall notes from the past few years it should be possible to get extremely close to what existed before.  If there was an analog processor in my recall list that I don't have anymore (like the NTP's or the Filteks) I think I'd still be able to get close and more than likely even better the previous results.  And the processors I've modded still work the same - they just are cleaner and/or easier to recall now.
If there were no recall notes either then I'd just as likely start over as I think I've learned a lot in the past few years experience here so I'm generally making better masters than when I first started working in here.
If the change requested was relatively minor (i.e. re-editing, perhaps a small eq cut)  then it's possible that I would work off the previous 16-bit master and just do some additional digital processing as needed.
Anyway - I actually did receive a call recently where a former Europadisk client was looking for their DMM's - for this particular kind of request unfortunately they are s.o.l. as the lathe was auctioned off to the Scientologists and the old masters sold to a scrap dealer.
Best regards,
Steve Berson
dave-G
Re: Your chain
« Reply #96 on: July 09, 2009, 07:13:23 pm »
TotalSonic wrote on Thu, 09 July 2009 17:50
Some things have in fact remained the same but lots of things have changed.
FIFY
*cough*
<g>
DAVE GREENBERG
SONOPOD MASTERING
Viitalahde
Re: Your chain
« Reply #97 on: February 25, 2011, 04:26:27 pm »
Hey Brad, may I suggest this topic among the ones to be moved to the other side? There's some good stuff in here.
Me, I'm at the core of my chain right now, and things are beginning sound really, really good.
HEDD D/A -> LCEQ (passive+tubes) -> Barry Porter EQ -> Knif Pure Mu -> FCS P3SL -> HEDD A/D.
I know I want and sometimes even need a simple low/high EQ.. And I'm going to wrap the LCEQ around an optional M/S matrix+filter set. WIth compressors, I'm going to have to cook it for a while, but so far it feels like I'm about done.
The number of inserts is reducing to two with a "hidden" insert in between. This holds the core of my chain, the BPEQ and the Knif. I'm trying to minimize the amount of cable and switch contacts, and suddenly daisy-chaining some stuff and taking stuff out with inserts instead of adding seems rationable to me.
Jaakko Viitalähde
Joe_Caithness
Re: Your chain
« Reply #98 on: March 03, 2011, 04:19:35 pm »
Cubase Essential 4 (why would I need anymore than this?)
Almost all the time for dance/club music it's something like:
PSP Neon HR (usually FAT + HI RES)
RME ADI2 DAC
GSSL DIY BUILD w/ API style TONE control mod and sidechain HPF
MEP250 inspired DIY BUILD w/ stepped everything, joint stereo
RME ADI2 ADC
VOXENGO ELEPHANT 3
Or variations of the above without stuff "in" if the mix doesn't need it.
Often for acoustic stuff, and sometimes for the rock stuff, I'll compress 1 or 2 dB with Oxford Dynamics, but often I won't if it's acoustic and just "use the headroom" when coming back into the DAW to gain and do any more I need with the Elephant with a dB or two of gain reduction if it sounds good.
Monitoring:
BENCHMARK DAC1
2xFOCAL SOLO 6be Nearfields
Pages: 1 ... 5 6 [7]   Go Up
