Author Topic: Loudspeaker cabinet tuning / Helmholtz resonance  (Read 14127 times)
audiothings
  • Real Full Name: Jai Shankar Iyer
« on: May 11, 2011, 11:42:57 PM »
Greetings to everyone and congratulations on the clean new look.
I had posted this question on a forum I use more frequently, but no answers forthcoming, I decided to peep in here.
A loudspeaker cabinet design software like (the free) WinISD lets you "tune" the cabinet, based on the following parameters: box volume, port shape and dimensions, number of ports, port length.
Can such a software be useful in the building of helmhotlz resonators?
Thank you.
Jai Shankar Iyer.
Thomas@Northward
  • Real Full Name: Thomas Jouanjean
Re: Loudspeaker cabinet tuning / Helmholtz resonance
« Reply #1 on: May 12, 2011, 08:20:36 AM »
Can such a software be useful in the building of helmholtz resonators?
Thank you.
Jai Shankar Iyer.
Well, check the exact parameters, but I don't see why not.
There are a lot of little excel tools on the net that can do that too. I'll try and see which ones I have buried on my HDD.
Northward Acoustics - Engineering and Designs.
Pro Audio Partners:
ATC Professional Loudspeakers
FOCAL Professional Loudspeaker
AMC Mecanocaucho Systems
boggy
  • R/E/P Forums
  • Real Full Name: Bogic Petrovic
  • There is no spoon...
« Reply #2 on: May 13, 2011, 09:13:51 AM »
.....based on the following parameters: box volume, port shape and dimensions, number of ports, port length.........
... and loudspeaker driver that you use in simulated bass reflex cabinet, with its (simulated) electro-mehanical impedance, based on Thiele/Small parameters. :)
From my experience calculators for helmholtz resonator at http://www.mh-audio.nl/ACalculators.asp works pretty well.
You can measure resonant frequency and Q factor of it (in your room) using method described here:  " Measuring Helmholtz absorber resonant frequency in non-anechoic space."
Even with loudspeaker modeling software you must always measure/tune/tweak (manually) resonant frequency for bass reflex cabinet (at end, when you finish it)... so you can't have much benefits from it (loudspeaker modeling software).
regards
franman
  • Real Full Name: Francis Manzella
« Reply #3 on: May 13, 2011, 01:42:08 PM »
Bogic,
That is a nice Helmholtz calculator... thanks for the link!!
FM
Francis Manzella
President - FM Design Ltd www.fmdesign.com
Managing Director - Griffin Audio USA www.griffinaudiousa.com
Zoyla1
  • Real Full Name: kaleem ullah
« Reply #4 on: April 04, 2015, 08:17:17 AM »
There are other companies that make similar competing products, but I have not found one that I like better than the Mason castings and installation technique. We use this solution on most projects that can afford the materials and support a concrete slab as the basis for floating rooms.
Page created in 0.081 seconds with 22 queries.
