Author Topic: Crossovers in Mastering  (Read 27455 times)
Noah Mintz Mastering
  • Lacquer Channel Mastering
« on: March 10, 2011, 09:13:43 PM »
Hi I hope it is ok for me to be posting this here. Most engineers know little about crossovers (as do I)
In my studio I have custom designed speakers. Soffett mounted.
Currently I'm using a Bryston crossover. The speaker designer is urging me to change it to a DBX Driverack crossover (or simular) so he can adequately set the delay, eq, and C/O points. The problem with that is the fact that the DBX is digital. I'm having a psychological issue with the digital conversion before output to the speakers.
Should I let the designer use the DBX or should I stick to my reservations and try and find an analog solution or keep the Bryston?
What crossovers are used in mastering rooms? It seems most racked crossovers are designed for PA systems.
Thanks for any input
Noah Mintz
Senior Mastering Engineer @ Lacquer Channel Mastering
http://www.lacquerchannel.com | [email protected]
Thomas@Northward
  • Real Full Name: Thomas Jouanjean
Re: Crossovers in Mastering
« Reply #1 on: March 11, 2011, 06:41:03 AM »
Well, the DBX could help you determine the best crossover points and then you can try and find or build a more suitable analog version with the required settings - so you avoid the AD/DA conversion?
Most speakers come already designed with proper implementation of the crossovers. So, at least myself, almost never have to deal with this.
Only when Subs are involved do we play with the CO, and it's usually the engineer that decides for himself the settings he is comfortable with over a period of a few weeks or months.
Northward Acoustics - Engineering and Designs.
Pro Audio Partners:
ATC Professional Loudspeakers
FOCAL Professional Loudspeaker
AMC Mecanocaucho Systems
franman
  • Real Full Name: Francis Manzella
« Reply #2 on: March 11, 2011, 07:03:13 AM »
Don't fear the crossover... My speaker company has some customers who offer a lot of resistance to the DSP crossover. (We typically use the DBX Driverack for stereo systems). I feel that my partner and myself are very discerning listeners and probably more critical than many of our clients. We used to use an active / passive design with a custom class-A active crossover between the lf and mid... then passive from mids to high. When we switched (upgraded) to the DSP units the difference was startling! The ability to do the fine tuning at the crossover points including individual driver adjustments, delay, etc. is such as improvement that it's no contest. The system just works and sounds better with these newer DSP crossovers.
Try it. You'll like it! There are no analog crossovers that can do what these boxes can do, PERIOD... Don't fear the crossover..
Also most of these boxes offer digital inputs so if you have a way to control the volume (in the box?) in the D domain you can skip the conversion all together... OR you can use one of your high end mastering A/D boxes as the monitor input DA and go into the crossover digitally while keeping your analog monitor and volume chain.. all options..
FM
Francis Manzella
President - FM Design Ltd www.fmdesign.com
Managing Director - Griffin Audio USA www.griffinaudiousa.com
« Reply #3 on: March 11, 2011, 04:08:54 PM »
Thanks Francis
Can you tell me are you using the expensive new 4800 models that do 96khz or the standard 260's that do 48khz?
Thanks again for your input.
Noah Mintz
franman
« Reply #4 on: March 11, 2011, 10:29:42 PM »
4820 units at 96K...
Francis Manzella
boggy
  • R/E/P Forums
  • Real Full Name: Bogic Petrovic
  • There is no spoon...
« Reply #5 on: March 12, 2011, 02:11:45 AM »
I agree with Thomas, you can use digital crossover for design purpose to test
crossover and next step can be building custom analog crossover. :)
AFAIK, Bryston crossover is very rough tool for building loudspeaker crossovers, because
in loudspeaker crossover design, it's needed to have more options for crossover frequency and
Q factor of filters than Bryston analog crossover can provide, and if you like to
have an analog crossover you may get it from properly custom designed analog crossover.
It's not possible to get acoustical Linkwitz-Riley response if we use filters,
before loudspeaker driver amplifiers, with only Linkwitz-Riley Q factor characteristic
because loudspeaker driver has its own response, that cascading response of line level
filter and cannot be successfully negligible. In this case loudspeaker designer can't do much
with it (Bryston), if you need fairly "flat" response with properly designed crossover
and equalizer. Although you don't need a baffle step compensation (usually low pass shelving filter),
because your loudspeakers are soffit mounted, there are probably needs for some eq filters that
Bryston crossover don't provide too.
Drawbacks for analog crossovers are:
- You can't build practical analog delay in overall range but only in band near to
crossover frequency (second one is almost all we practically need from delay in crossover
 design, btw)
- In some situations, proper crossover/eq may be too complex for analog realization.
- You cannot program or "tweak" it after design... without component changing.
Advantages:
- you can have a classical gain regulation before crossover.
Realization of an analog crossover may be similar to Siegfried Linkwitz Phoenix design,
you can see it at this page http://www.linkwitzlab.com/xo_eq.htm
With digital realization of crossover you can have practical digital delay,
in overall band, and filters may be much more complex without many drawbacks...
But you may have problems with gain regulation.
Digital gain regulation without applied dithering probably isn't a best way because
you will have audible quantization errors (quantization noise) when levels are low.
One of possible ways to solve this is to use multichannel analog gain regulation
after crossover D/A converters.
If you don't like D/A converters from DBX crossover, you can probably use crossover with digital
outputs, then you can use external D/A converters whichever you like.
I'll try to avoid A-to-D conversion at input, and will use digital input only. Volume (gain) regulation
may be digital, in crossover itself, but with dithering applied, controlled with some practical remote ctl.
New product in this area, that may do this, is DLCP from Hypex, and, if I remember correctly, it have
dither generator in DSP, I'm not sure about digital outputs, but overall system seems to be properly designed,
including a decent D/A converters (low phase noise oscillator,... etc.).
and, AFAIK, this product isn't designed for PA systems (but may be used for... :) )...
http://www.hypex.nl/?var1=http://www.hypex.nl/products/DLCP.html
Maximum input S/R is 192kHz, internal S/R is 96kHz, and in DSP they used, there are also 48bit data path,
76bit Multiply-And-Accumulate (MAC) and 28bit for coefficients,
you possibly don't need more than that for any purpose, mastering studio included. :)
And I agree that digital crossovers aren't a problem you may fear, they can be excellent if, as always, implemented properly.
Best regards
franman
« Reply #6 on: March 12, 2011, 08:37:03 AM »
yeah... all that stuff that Bogic just said!
Francis Manzella
Thomas@Northward
« Reply #7 on: March 12, 2011, 04:03:49 PM »
I really need to get some Hypex amps and test them on the mains at the studio. I heard them many times in studios (especially mastering) it's like there is an extra LF octave.
Tight.
Pro Audio Partners:
franman
« Reply #8 on: March 13, 2011, 12:18:16 PM »
Noah,
Who designed your mastering room (and your custom loudspeakers?)... why did choose to go with in-wall speakers?? I've done a lot of high end mastering rooms and everyone of these guys has selected free standing (hi-fi) speakers... just curious.
FM
Francis Manzella
« Reply #9 on: March 14, 2011, 02:57:27 PM »
Our rooms were actually designed in 1989 by Group One Acoustics, Terry Medwedyk. I was not involved with the studio at that time. I believe in-wall speakers were the flavour of the moment... but I can't be sure.
Here is a pic of the room:   The speakers have been lowered about a foot since the picture was taken.
I'm happy with the set-up but I do realize I can get better performance out of these speakers with proper crossover as the designer had intended.
Phil, my partner here at the studio, occupies the other room (which is mirrored to mine) has moved to floor standing speakers and had not looked back. I'm determined to stick with the in-wall for now but that may change in the future.
I've been eyeing these crossovers on ebay: http://tinyurl.com/4rtox8g price seems right and offer 96khz conversion.
The speakers were designed by Steve Kranis at Audio Hardware: http://www.audiohardware.ca/
Noah,
FM
Noah Mintz
DanDan
  • Real Full Name: Dan FitzGerald
« Reply #10 on: June 02, 2011, 01:25:14 PM »
Perhaps you could rent or borrow some crossovers before you commit.  I had some PMC speakers on trial some time ago. They said many of their clients used a Sony speaker processor. Sorry can't remember the model. In live/PA work I have used the XTA products on many occasions.
No A/B comparisons but I felt confident with the operation, build quality, the general vibe off them.
I typically turn down the power amps to 50% or even lower, in order to get something happening on the meters of such digital units.
Not much point running a 24Bit unit at 12-14 Bits!
DD
Dan FitzGerald  MIOA MAES
www.irishacoustics.com
www.soundsound.ie
franman
« Reply #11 on: June 04, 2011, 12:56:15 AM »
The Dolby Lake is a great sounding unit. We've never cared for the GUI that much, but it is a great sounding box. We also use the DBX 4820 Driverack and BSS London BLU Series for larger systems. All great sounding boxes.... My experience with XTA is  you get a lot for the money, but it's really not a high end box. Probably difference is in the design and cost of the analog stages which is quite important in these boxes. Of course, stable clocks and great nice converters are a must as well...... (probably said all this before.. but..)
FM
Francis Manzella
boggy
  • R/E/P Forums
« Reply #12 on: June 04, 2011, 01:17:31 AM »
The Dolby Lake is a great sounding unit.........
BTW, I search recently for Lake Technology,
and I found it now in Lab Gruppen http://lake.labgruppen.com/ :)
Best regards,
Wireline
« Reply #13 on: June 04, 2011, 11:06:37 AM »
Is there a real benefit to using active or passive crossovers as opposed to using tuned speaker enclosures as crossovers?  Some cabinet designs roll off the low end by design, others the high end, again by design.
I don't know - this is why I am asking.
Ken Morgan
Wireline Studio
Midland, TX
boggy
  • R/E/P Forums
« Reply #14 on: June 04, 2011, 11:52:28 AM »
Couple of reasons that crossed my mind:
- generally, tweeters will be damaged without any electrical high pass filter applied (analog active, analog passive or digital active...),
- also, many other loudspeaker drivers needs a high pass electrical filters to avoid damage (or heavy distortion, at least), when higher power is applied (anything greater than 1W)
- designing electrical filters is easier, cheaper and  more accurate than designing acoustical filters.
- digital filters give even more freedom (there may be many more without serious degradation of signal or impedance, and we can have presets, A/B testing is much easier)
Best regards
Page created in 0.06 seconds with 21 queries.
