blueboy wrote on Sun, 06 November 2005 22:42 |
If a 44.1/16 audio file that has been dithered to 16bits is then upsampled to 48/16, what is the effect on the dither?
As the intent of dither is to remove the correlation between the signal and the noise from quantization errors, and upsampling will affect levels in the newly created audio file, will the benefit of dither be negated, or will the impact be minimal?
For some background on why I am asking this, read here:
http://recforums.prosoundweb.com/index.php/t/7841/11771/?SQ= a4d174223251e166079352196d139fb7
I find it hard to believe that this would be done to a mastered audio file, but I am just curious as to technically what would happen.
Thanks.
JL
I would dither a second time, when taking the output of the SRC down to 16 bits. But this time, the need for dither, as well as it's effectiveness will be less then the first time you dithered.
Why? because, the noise floor of the original signal is a bit higher then the noise floor of a raw unditherd signal. The idea of using dither requires that the signal be accurate to better then the final word length.
An extreme example: say you have -60dB noise floor or so. The noise is so high that it does not matter what you do at bit 16.
Using dither on dither is not as extreme as -60dB dynamics, but you are "somewhere in between" needing (or not) and benefiting (or not) from more dither.
I will test it and get back with more solid statement. My best guess is to dither a second time. Most of the trad off is already done, and more dither will not add too much noise... The noise degradation second time is a lot lower...
Regards
Dan Lavry
www.lavryengineering.com
