Always the same problem ... just a remark ... what are you using to listen to classical music ? Digital hi end modern sytem ? Audiophile analog ?
Do you prefer modern ddd recordings or old good vinyls ?
I personnaly prefer vinyls ... they simply deliver you music not analytic flow of bits ... vinyls have necessary been compressed but all artefacts usually associated with compressors are surprisingly unhearable or so musical (following the natural compression curve of our ears ) that nothing disturbs you during the listenning process ...
when it commes to "density" or physical impact , digital uncompressed recordings always seemed to "forget" something during process and deliver something clean and precise but loosing the "glue" that makes an orchestra sounding like a bunch of musicians delivering music and swet, not individual sections playing their scores dramatically "cuted" from the rest ...
Ok you can say "coloured" or harmonic distortion or reduced transcients or dynamic or whatever ! I always founded digital "coloured" , ok, in a very different way than analog but i remember back in the beginning 80's when every good engeneer could recognise at the first sight that a cassette was copied from a CD source or from a vinyl just because of their sharp and very bright colour compared to analog sources ...
Back in our days when someone comes to me talking about transparency it just gives me ideas for my girlfriend's wardrobe, and let me think that the gear he's talking about has just ... no balls ! Classical music NEEDS compression , exactly in the same way than your ears are compressing the signal comming from a big orchestra playing in front of you ... Modern pre's are way too clean have way too much headroom to be pleasent to my ears ... i prefer iron and discrete electronics
... it follows bandwidth more gently than the straight modern designs .... what about capacitors in this case ? And op amps ? and surface mounted components ... pfffffff !
My first meeting with the SOUND was on my uncle's pair of Tannoys driven by KT88's QUAD amps with tangential REVOX playing Sgt Peppers at loud volume ... i was 8 ... i will never forget it ... and every time i switch my studio on and listen to this system ( now my main monitoring system ,here, at Colourbox ) with a fellow ... i can see on his face probably same expression that i must have at 8 ! Magic stills operate ! When it comes to recording i use both methods : a gentle tube limiting and a gentle fader following with the score under the eyes , if i consider the gentle compression of my analog recorder (telefunken m36) pushed very hard and with a (fantastic !) modern tape , the noise floor stays enough quiet to justify the musicality this system gives you ... ok , every time i'm recording classical musicians , it is for a pop production or a film score not a classical CD release, but i think that no conductor is unsensible to musicality ! sorry for my crap english ... i'm french !
(I'm the proud owner of a huge bunch of tube mics and pre's from RADIO FRANCE 60's used at their time to record classical music ... coloured it is ! But try every modern pre with a string section in front of those monsters (100lbs of iron and 5 tubes for one single channel !) and you'll understand why i'm so proud !)
