Yannick wrote:"Stagetec Truematch are 28 bit AD converters, with 48V - so you do not need a mic preamp. You just plug the mic into the AD converter."
The Treumatch AD converter has a mike preamp on board, only you do not control the gain in the analog domain. Each input consists out of 4 preamps and 4 AD converters. The first has approximately 60 dB gain, the second has approx. 40 dB gain, the third approx. 20 dB gain and the fourth has no gain. The system automatically chooses that gain level which brings the followed AD converter in it's best converting area. To scale the converters outputlevel to a workable level into your desk or recorder, you use digital gain when necessary.
When Stagetec invented and patented their system, Prism Audio already had gainranging AD converters. In those days there were only 18 bit converters, so indeed it was a clever idea to use gainranging. Stagetec used gainranging, only they called it Truematch.
Although the Truematch system claims to compensate for all kinds of digital anomalies, even when using the same opamps for amplification of each stage, every stage will sound differently. If you take an AD797, it sounds completely different when 10 dB or 30 dB is applied. Normally when you set your preamp for 40 dB of gain, you realize one sort of colour, but imagine if you connect your microphone to 4 preamp channels and 4 AD converter channels and you apply 0, 20, 40 and 60 dB gain, and everytime when the signal drops under -20 dBFS of the converter which is in action, you crossfade in your workstation to the second layer, with 20 dB more gain, and if it gets too loud, you do it the other way around, you go to the next lower gain. The effect will be different colouring for all different level segments you operate in.
BTW: The Schoeps CMD2 uses one 24 bit AD converter, no gain ranging whatsoever.
Erik Sikkema
