Author Topic: Media for Tascam DV-RA 1000  (Read 1111 times)
Alexaudio
« on: October 26, 2005, 05:53:00 pm »
We are about to commit to buying a Tascam DV-RA1000.  After evaluating our needs, cost factor, etc - we have found this piece to be an excellent fit.  Question remains however, is this unit sensitive to particular DVD+RW media?  Fred B's review in Pro Audio Review suggests that it is...however I have heard at the AES that it works well with many name brand DVD+RWs.  We have been testing it with Sony DVD+RW without a hitch.  However, the cost factor for Sony's is a little high since I have been grabbing it at Staples.  One of two media suppliers we use has Verbatim DVD+RW.  Should I be concerned before buying a few spindles?
Alex Kosiorek
Audio Recording & Mastering Engineer
Corbett Studio / WGUC-FM, Cincinnati
Audio System & Processing Consultant
Imagine
Re: Media for Tascam DV-RA 1000
« Reply #1 on: October 27, 2005, 02:03:34 am »
I've been using the Memorex DVD+RW, but have had quite a few unreadable disks on my G5 and G4 computer. They should be compatible, but I suggest trying a few others before you commit to them.
Fifthcircle
« Reply #2 on: November 02, 2005, 02:19:43 pm »
One of the local rental houses here in LA has them, but I know they have spent a lot of time trying to find media that is reliable.  Unfortunately, I don't know the results of that search other than it has been a bit trying at times...
It is also more of an issue at high-res as the data throughput is much higher.  At standard resolutions (24 bit/44.1K for example), there is a lot out there that works...
--Ben
Benjamin Maas
Fifth Circle Audio
Los Angeles, CA
http://www.fifthcircle.com
