bobkatz wrote on Mon, 31 October 2005 09:24 |
JamSync wrote on Mon, 31 October 2005 00:06 |
Yeah...it's like if my mom had accepted the job with Linus Pauling instead of marrying my father, who would I be?
You'd be dispensing vitamin C instead of good audio advice?
BK
would those be SLOW response vitamins? get it, C weighted?
oh, sometimes i KILL me
iguana:
yes that site is about SR, matrixed 2channel that unfolds into vainglorious 4.0! LCR mono S. LtRt, or Left Total Right total -- stereo is LoRo Left Only Right Only, and Z-axis playback is ZoRo. and SoZo and SoHo and BoBo and HoMo and... as i adumbrated to in one of my posts, it is corn-fusing. dolby use to call noise reduction (and still do, SR -Spectral Recording...) your Ste-REO speedwagon Mix going to 35MM at a Lab:: it will have this types of Dolby A replacement Noise reduction: SR.
here is some poop:
Dolby Stereo (LCRS-->LtRt-->Dolby A encode-->OpticalTrack-->Dolby A decode-->LCRS) 4:2:4 matrix described above with Dolby A type noise reduction. Dolby A is no longer favored, instead use Dolby SR.
Dolby SR (LCRS-->LtRt-->Dolby SR encode-->OpticalTrack-->Dolby SR decode-->LCRS) 4:2:4 matrix described above with Dolby SR type noise reduction. This is the same as Dolby Stereo except that the optical track is encoded with SR instead of A type noise reduction. This format is still used for surround audio from film optical and as the backup track for Dolby Digital. The terms Dolby SR and Dolby Stereo are often interchanged, incorrectly.
Dolby Digital a.k.a. AC-3 5.1-->AC-3 data stream-->5.1 The compressed data stream supports up to 5 full bandwidth plus one low frequency effects channel. It is designed for film, broadcast, and DVD final audio delivery. It is NOT considered "editable", which means you cannot just "punch in" on the data stream without consequences. This is the digital audio part of Dolby SR-D and Digitial Cinema.
Dolby SR-D is a dual-stream audio delivery system printed on the film, with a Dolby SR optical track and blocks of bits printed between sprocket holes that, when reconstructed, form the AC-3 digital audio stream. Since both technologies (Dolby Digital and Dolby SR)are present on the same piece of film, the print will play in any theater, whether or not equiped with Dolby Digital equipment. unless the projectionist is drunk!
hey, when is johhnny b gonna say that analog optical playback rules and dolby digital or DTS playback sucks?
oh, and if the SR playback sucks, i can fix it with drastic EQ cuts!
