Augustine Leudar wrote on Wed, 26 October 2005 12:57 |
To be a bit clearer.
I have to do a ten speaker diffusion project at college (10 speaker surround). At college they use ten Mackies. I cant afford ten mackies. I have one pair of good quality monitors. I make all the sounds on them. However I need to do the sound design at home otherwise I have to do it on college equipment which means if im lucky ill get half an hour a week. I need to do it at home becaus I like to spend maybe 8 hours a day on it. So all I want to know is if the Behringers are good enough to position the sound at home (using a 8 channel setup in protools / nuendo ) to later transfer them on to the Mackies at college or the performance space. ?????
So basically it sounds like noise and even distortion aren't so crucial for this specific application, what you care about is...
1) Does it render the frequencies you need?
2) Does it keep phase in a reasonable state?
For evaluating surround positioning I would guess that phase is going to be more important than flat frequency response.
Perhaps you can get this information from Behringer?
