Quote: |
As for hearing the difference, that is most likely down to those high frequencies combined with non-linearities in your output stages and transducers generating components in the audible range.
absolutely NOT.
I'm afraid I've heard the results too many times to think it's added 'components'.
Whatever it's doing, it's doing BETTER, because the effect is not good sound but REALISM.
You can make a sound more present and in your face by increasing voltage and current (reducing plate resistance).
I was just doing this the other day, and I did look at a 150 KHz square wave on the oscilloscope to see how much it would change..just for curiosity's sake, it does change a little in shape, becoming more squared off (this also depends on the capacitance of the load).
the end result is that the transients are more realistic and 'air-like'.
the voices sound like they are 'in front' drums have a distinct presence.
the fact that the bandwidth is increasing over the hundreds of KHz shows that it's not to do with the 20-20KHz sine response but something to do with sharp impulse response.
...MIND YOU, I didn't say I think that this has to do EXCLUSIVELY with the increased frequency response, I am talking about how the electronics
react to transients, and trust me.. every kind of active component reacts differently.
it's easy to get caught up in technical jargon that can make sense out of complex reality.
it's more difficult to deal with reality effectively.. much more difficult and time-consuming..
Anyway... what I said before.
