R/E/P > Brad Blackwood
Euphonic Analog Transfer Console (ATC-1)
<< < (2/13) > >>
bblackwood:
OTR-jkl wrote on Thu, 18 August 2005 12:49
Hey Brad -
I've always wondered how you determine the order of your inserts...
Does it follow 1-2-3-4-5-6 and you have to repatch if you decide to change the gear order? IOW, if your Sontec is patched to Insert #1 and the Ibis is in Insert #2 and you decide that you want to hit the Ibis first and then the Sontec, do you repatch on the back? or what...?
Yep, the order is set - if I need to change it I crawl underneath...
OTR-jkl:
What I thought.
Thnx.
stereopw:
HI Brad,
I am new to the forum....thanks for all these great infos....
Sorry for these basic questions....
Is the ATC1 the console you are using everyday ?
Is there any electonics inside ? (or is that only switches, I mean...)
Are you using a M-S system to master ? (using the ATC-1)
On that console you have only one output for 1 pair of speaker or are you using a switcher after it ?
Thanks for the info....
bblackwood:
stereopw wrote on Thu, 18 August 2005 16:18
Yes.
Nope, completely passive.
Not in the ATC-1, no.
I only have one pair of speakers in the mastering room.
stereopw:
Thanks Brad !
Phil
PS : When you use MS do you have an other console ?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
