Hi, I have a trak 2 and love it, did have one problem early on when the original digi ambus card (to connect to a mix plus system) was making clicks and pops, Apogee admitted it had a problem and they did an update eprom chip which they gave me. I wonder if the card might have a problem, You might try taking it out and re-seating it too. Also if you are familiar with the trak 2 clocking window, when you set it to a sample rate, like 44.1 for ex. you then have to push click the main dial to lock or set that setting, just because the number is in the window does not mean it is locked to that setting, when you click the wheel, it will say "system locked 44.1" in the bottom for the that sample rate page. Also there are two types of resets on the trak 2, try both, I have had weirdness where I got no audio thru and had to reset and then it was fine. It is a great sounding box though so obviously something is wacky with your set up or the unit. By the way, the guy at apogee to talk to about the trak 2 is Roger, he is the only one who really knows it inside and out, you might give him a buzz and have him talk you thru some checks. S
