Author Topic: Please Critque my first Studio Setup  (Read 6639 times)
Zephyr
« on: October 05, 2005, 03:32:41 AM »
Hi, I will be forming my own entry-level studio very shortly and need some suggestions and critisisms of of my potential gear selection. This is not intended to be a Pro Level Studio... More of a "starter" studio that is appealing enough for me to get bands in to to practice tracking and mixing for free (And possibly rent out), and have the capability of an acceptable sound.
Here's the List of gear currently owned:
Motu 896 + Digimax LT
Mackie HR-824 Pair
Oktava MKL-2500
Groove Tubes GT-55
Nuendo 2.0
Gear I have been eyeing/intend to purchase:
Yamaha MG-16/4 (For Cue Mixes, Talkbacks, And Control Room Volume)
Lexicon MPX-1
Universal Audio UAD-1 Ultra Pack
2x ART ProChannels
Furman PB-48 Patch Bay (Signals will be multed after pres so one path goes to MOTU, and other goes to Cue Mixer)
3x Sure SM57
1 x Sennheiser E-602 mic
3x Sennheiser E-604 mics
2X Sennheiser E-914 mics
2x Audio Technica AT4040 mics
Plus 1 some what high-end LDC
1x Bass DI
Well, that's basically it. The list doesnt include things like Headphones, cables and stands, or room treatment...
I've used some of these microphones before (The 4040s, 602, 604s, and 57s) and liked the sound...
I know Hi-End Pre amps are very desirable, but I dont want to invest 2K on them right now.... When/If I start charging people and turn into a commercial studio, then I'll go all out and invest 5-10K in pres.
Anyway, Critiques would be very appreciated... also Interested what people would suggest for the LDC (One $500-800 that has the "I'm on the Radio" type sound) and what they think about the E-914s too.
Thanks
- kelly
BoMoFo
Re: Please Critque my first Studio Setup
« Reply #1 on: October 05, 2005, 10:57:32 AM »
It looks like you are off to a great start kelly.
the only "critque" i have to offer you is consider a different cue solution than simply doing a mult after the pres.  If you work with players with their cue send after the preamp then on playbacks they will not hear the recorded track.  Probably what you would like to do would be work through another output of the Motu that is set up as an aux send output (aka a cue send) and put that into the cans.  Nothing different gearwise, just a slight change in routing.
B!
Vertigo
« Reply #2 on: October 05, 2005, 02:59:24 PM »
The MOTU 896 comes with CueMix - zero latency monitoring and all of the routing options you could possibly need. So forget about multing your pre's, you won't have to Wink
Personally I'd recommend a Beta52 or a D6 over the e602. I have an e602 and have never found it particularly useful.
The e604's are great - the trick is that you have to aim them at the center of the drum, NOT directly down at the drum head. I had to learn one that the hard way  Rolling Eyes
-Lance
John Ivan
« Reply #3 on: October 05, 2005, 03:05:49 PM »
Kelly wrote on Wed, 05 October 2005 02:32
Mackie HR-824 Pair
Oktava MKL-2500
Groove Tubes GT-55
Nuendo 2.0
Lexicon MPX-1
2x ART ProChannels
3x Sure SM57
1x Bass DI
Thanks
- kelly
Hi Kelly,
I would look for a used sound craft console. The low end Yamaha's are sorta cheap and if you look around, you can find a great little 16 channels4 sound craft. Also, you could do away with the art channels and spend that money on more/better mics.{use the pre's in the mixer.}
I don't know much about the E-series mic's but, I love the AT stuff.
The UAD is a great choice too.
Looks like your on the right track. I just have a thing for old work horse mixers. :-}
Ivan..............
"Transformation is no easy trick: It's what art promises and usually doesn't deliver." Garrison Keillor
Frob
« Reply #4 on: October 05, 2005, 03:34:15 PM »
i would ditch the art PROchanels get a couple of groove tubes bricks insted, the EQ and Compersors on the UAD1 will be more then adaquate, and for the LDC i would recomend two mics that if you shap around will top you out at the 800, first the at4047 this is a great dark growl mic, and is fanstic on manny things you want that 70s fet type sound. the other is the CAD M9 this is a crystal clear mic with smooth transparent highs, and sensative as hell.
Zephyr
« Reply #5 on: October 05, 2005, 08:37:06 PM »
"Personally I'd recommend a Beta52 or a D6 over the e602. I have an e602 and have never found it particularly useful."
Every time we used the E602, it sounded good (And the 603s), but the pre-EQ on it makes me wonder about how varied it can sound. I'll look at the D6.
"I would look for a used sound craft console. The low end Yamaha's are sorta cheap and if you look around, you can find a great little 16 channels4 sound craft."
I was actually considering the soundcrafts before the MG. I ran into both of them in a store, and the MG won me over because of the actually decent spacing between knobs, and I liked the feel of the faders better. I think the MG's pre's are noiser, but it doesnt really matter considering it's only going to be used for the cue and talk-back. None of the low end console pres interest me Razz
I will consider ditching the ART ProChannels.
I didnt intend to use the Pres on them often, but instead use them to compress ans EQ signals on the way into the MOTU. I also wanted to use them as outboard compressors in Nuendo, since Nuendo 2.0 can latency compensate for analog hardware. I liked the way the ART VLAs sounded, and for a little bit more you get EQs and relatively fast Vari-Mu compression.
I havent heard a software compressor that I've liked better than hardware yet either (Barring the High-ends Waves plugs). Maybe the UAD system will change that.
Thanks people
Ps: Any more rock/alternative LDC vocal mic suggestions?
spankenstein
« Reply #6 on: October 06, 2005, 09:43:00 AM »
I would skip the board unless you are mixing outboard. I have so much flexibility with my 828mkII that I don't need a mixer anymore. I'm now eyeing some for analog mixing but you don't need that for monitoring.
redfro
« Reply #7 on: October 06, 2005, 10:43:09 AM »
Vertigo wrote on Wed, 05 October 2005 13:59
I would chose the 602 over the D6 or the Shure any day. I actually just sold my D6 cause, outside of live work, I've never had it work for my sound. And the Beta 52 I don't even like for live work.
Just goes to show, try out everything in your space and pick what you like, not what some hack like me tells you is cool.  Laughing
Wes Pitzer
WCS Media
redfro
« Reply #8 on: October 06, 2005, 10:44:53 AM »
...and now, my 100th post....
....wow, that was exciting.
Wes Pitzer
WCS Media
John Ivan
« Reply #9 on: October 06, 2005, 11:14:21 AM »
spankenstein wrote on Thu, 06 October 2005 08:43
Yes, it's true you don't need this for monitoring. I think having a console can be really good for someone who is learning this craft. You can mix in the box and then,mix on the console to hear the difference. And,you can do both. Do some editing and some comps in the box and bring stuff out to the mixer in groups. There can be a big big difference in the EQ's AND in how the channels on the mixer and the buses sound compared to the box.
It's just a great learning tool and I think it sounds better.
My 2 cents.
Ivan............
tats_dragon
« Reply #10 on: October 06, 2005, 01:30:06 PM »
Frob,
Just wondering for what sources you used the Pro Channel on. I've read (of course, I believe everything I read on the net)with a tube change these units are quite good.
I will be using it for my Akai DPS24 and possibly as an acoustic guitar preamp for live as well.
Jun
Frob
« Reply #11 on: October 06, 2005, 01:30:48 PM »
i know exactly what your talking about when it comes to soft compressors and yes the UAD1 will change that, and the comps in the art i havent used so i cant comment on. also why nuendo? why not Cubase? unless your woking in a workstation envroment there is litle that nuendo can do that cubase sx cant.
Jeff4h
« Reply #12 on: October 06, 2005, 07:33:24 PM »
I dont think you need a board, I use the mackie universal controller and it is great, Im not that familiar with some of the gear you have, I have a presonus central station and it is great for the control room, you will love the uad-1 card, it is awsome, the fairchild is unreal along with the 1176, L2, and the pultech stuff and the new plate reverb is great, stick with that what ever you do, you can pick up some older hi end reverbs by yamaha like the rev 7 that still sound wonderful, good luck
                                                Jeff
Vertigo
« Reply #13 on: October 07, 2005, 08:50:16 AM »
Yeah, you can't go wrong with the UAD. The 1176 and Fairchild are smoking, and the LA2A has been my secret weapon for heavy guitars for a while now. I find the 1176SE to be a surprise winner too - very different than the 1176LN, but almost equally as useful. The EMT is great for a lot of things, and I've gotten a LOT of use out of the new CE1.
You're going to love the UAD Wink
Check out the waves Ren plug-ins too, VERY useful. The RComp was the first plug-in I ever heard that sounded "warm".
-Lance
John Ivan
« Reply #14 on: October 07, 2005, 10:30:49 AM »
Kelly wrote on Wed, 05 October 2005 19:37
Thanks people
Hi Kelly.
To be clear, I was talking about the old sound craft consoles, like a 200-B or one of the old studio consoles. The pre's in those can sound very very good for the money.. The EQ's can sound REALLY REALLY Great too.Your idea about the ART units is good. The VLA's do sound nice and you can use em'' in the computer rig...
As has been stated here,,if you don't want to mix on a console,and you don't need the pre's, get one of those master section controller's and a surface of some kind. Those master deals are cool. you can monitor a bunch of different stuff, check Mono and all the other stuff the control room section of a console will do..
Ivan..............
Page created in 0.127 seconds with 19 queries.
