blue_orange wrote on Sun, 18 September 2005 19:09 |
Is it necessary to turn on the dither when using digital saturation? Even in 24 bit conversion? I assuming this d.sat is such a dsp processing that might truncate bits..
Any thoughts?
BO
Dither at 24 bits? It will make no difference if it is on or off. The use of dither is for when ever you reduce word length, and given that a 24 bits is all you can have (in digital audio data), if you stay at 24 bits, there is no need for dither. Also, at 24 bits, the signal converter noise floor is so much lower than the 24 bits data, that the dither will be buried under the signal noise.
But say you want to reduce the signal from 24 bits to 16 bits. Now you need dither. The soft saturation effects the high level (loud) music, and these are the times where dither does not help you. But when you have a quite part of the music, the converter act in a "regular way", and you will need dither.
So I suggest to view saturation and dither as separate issues. Saturation is for the "music peaks" and for the top range, and dither is for when the music is not loud.
Regards
Dan Lavry
wwew.lavryengineering.com
