bobkatz wrote on Sat, 17 September 2005 15:39 |
sui-city wrote on Thu, 15 September 2005 16:54 |
Well, I think it is the definition of "mediocre" that we'd have to define. Obviously, if you put in a 25 cent jittery crystal oscillator as an afterthought, then it is conceivable that even a crappy PLL will do better. But what a stupid way to run a company...
BK
Quote: |
Quote: |
Bob,
Have you got any examples of businesses run like this? A yes or no will suffice if you don't wish to name names.
It's not as bad as I describe. It's mostly ignorance and lack of test equipment or PLL or oscillator expertise on the part of the designers. Coupled with pinching pennies.
This isn't good, if it's true...
1. If I remember, some of jitter/wander measurement instruments costs are greatly lowered, but it is still very expensive even today... look at:
http://www.sunrisetelecom.com/pages/jitter.shtmlhttp://www.acterna.com/global/index.html (ex Wandel&Goltermann)
http://www.agilent.com/ (ex. Hewlett Packard)
This companies have some history in jitter/wander measurements, especially last two...
Some of their instruments _must_ be used if any digital audio equipment manufacturer tend to be authoritative.
2. Manufacturer can use their own, already properly tested, old designs copied and pasted in new design, but this does not means that new design is already jitter/wander free... Manufacturer must have possibility to check design again and again... there is too much jitter/wander sources than we can expected (PCB design may have great influence for example)
3. PLLs in digital audio has very sharp requirements if we look at AES recommendation named as AES11 (look at
http://www.aes.org/publications/standards/)
I don't have idea how it's possible to make some 1000$ AtoD audio equipment if this is a comparable to price of one single good (but not the best!) TCVCXO unit (Temperature Compensated Voltage Controlled Crystall Oscillator)
Quote: |
In essence, consider that a single 2 channel converter of superior quality can cost 3 to 4 times as much as an 8 or 16 channel converter of "medium quality" and you'll see where the money goes.
I get people who write me that their brand x 16 channel converter for which they paid $800 to $1000 sounds better on external clock. OK, so then the only conclusion I can make is that the internal clock was designed too cheaply. The converter is what I call "defective". But that is not the same as saying, "you got good value for your money." Maybe you did . The sound quality of even a "medium level" 16 channel converter made today is often better than that of certain more expensive 16 channel converters made 8 to 10 years ago. Simply because the parts are better.
Probably only analog audio can have "good value for money" scale...
If digital audio devices aren't so good, this is not that inaudible or tolerable.
And yes, new component are almost always better and cheaper than oldest one... this is wonderfull
Engineers always has new tasks (jobs!)
Quote: |
-snip- I have not tested many, no one pays me to test these things
Why?
Best regards,
-boggy
