Pages: 1 2 [3]  All   Go Down
Author Topic: cheap guitar amp for clean tones  (Read 14182 times)
JDNelson
Re: cheap guitar amp for clean tones
« Reply #30 on: April 21, 2008, 01:51:30 PM »
josh wrote on Wed, 31 August 2005 11:09
Checked out a Fender Pro Jr...  not great.  Speaker stinks.  Maybe into an external cabinet it'd be ok.  Haven't tried it.
FWIW, I had a chance to A/B one of these with a Blackface Fender Deluxe Reverb, just for kicks and giggles.  The Pro Jr. sounded like a transistor radio by comparison.  It'd maybe be a good emergency amp for a small bar/restaurant gig or something, throw it in the trunk "just in case", but I wouldn't rate it higher than that.
garret
« Reply #31 on: April 21, 2008, 02:13:28 PM »
The Tech21 Trademark 30 is an interesting little amp for <$300.  It's basically a Sansamp unit in a cabinet, with a clean 30 watt amp, a 10" speaker, and an accutronics spring reverb.
Great for taking to band practice (it's only 14 lbs!), and you can record with the sansamp as a DI.
tomorrow is already here - http://www.worksongs.net/
A.J.
« Reply #32 on: April 21, 2008, 03:28:26 PM »
I've been gigging with a Tech 21 Trademark 60 for the last bunch of years and I think it has it great tone. The clean channel can do just about any sound pretty well. And like Garrett said, they're easy to lug around. I think mine is 36 lbs.
Ian Visible
« Reply #33 on: April 22, 2008, 08:07:03 AM »
Roland Micro Cube
I've been pleasantly surprised by the clean sound both times I've heard it.
It's a sound that sounds like it shouldn't be coming out of a box that small.
Fibes
« Reply #34 on: April 22, 2008, 09:31:02 AM »
A good clean sound that sits well is a lot tougher than one that just sounds good. Many times the right ticket is a dual set of DIs into good pres and a healthy dose of the right compression.
Yep, I said direct.
It doesn't have to be papery and lifeless.
Otherwise I'm all about Fender twins (even the red knob ones), Deluxes, and silverface Princetons.
I have enjoyed the Vox Pathfinder but it's not my go to amp for these duties which is my Tone King Imperial (think deluxe).
I always hate to tell people to spend more but a 600 dollar silverface fender will hold its value...
Fibes
"You can like it, or not like it."
The Studio
  http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewArtist ?id=155759887
http://cdbaby.com/cd/superhorse
http://cdbaby.com/cd/superhorse2
Nick Sevilla
« Reply #35 on: April 22, 2008, 05:43:40 PM »
Even those amps that the bands are bringing in can get clean tones, I'm sur of it.
It just requires tweaking those knobs, especially the "gain" knob before the EQ / output section. Back that off, and the guiar cleans up.
Cheers
PS what kind of amps are they bringing in that don't sound clean?
A 100Watt Marshall will sound clean, if set up properly...
It is quite possible, captain, that they find us grotesque and ugly and many people fear beings different from themselves.
www.nicksevilla.com
Secular_Tool
« Reply #36 on: June 15, 2008, 02:31:42 PM »
Late '70/early '80s Peavey Vintage series amps are usually a bargain when you can find them. I paid $200 for mine in '94 and it looks like on they are about the same range on EBAY and other used markets when they appear.
I have the 212 version and it rocks.
Pete Townsend used the 410 version on Rough Mix and Face Dances
 http://www.thewho.net/whotabs/equipment/guitar/equip-peaveyv intage.html
There was a taller 410 or 610 version in the same series.
It is not the much later "classic" series that look very similar but have totally different designs and prices.
I have an early '80s peavey 2x12 classic which seem fairly rare but cheap when you can find them. Mine was around $200 when I found it.
I blew up the Jensen speakers and replaced them with celestions.
There's no master volume so I've never gotten it loud enough to see what the preamp sounds like over driven. I put a variac on it to hear what it sounded like turned up all the way, and it didn't suck.
The clean tones are really, really sweet. Put a ross or dyna comp on it and it's twang heaven.
Putting fuzz boxes on it sounds pretty good as well. Not as good as an amp with a tube front end, but pretty good.
The clean tones are as good as anything I've used.
hargerst
« Reply #37 on: June 15, 2008, 03:27:23 PM »
You want cheap, clean, AND dirty?  Try a 15 watt Fender Frontman, into a 4x12 Marshall cabinet.
Harvey "Is that the right note?" Gerst
Indian Trail Recording Studio
SpiderM69
« Reply #38 on: July 19, 2008, 01:05:19 AM »
It's not exactly $200, but the new Princeton Reissue is awesome.  I wasn't in the market for a new amp, didn't need one, didn't want one, but happened to be in a music store getting strings.  Plugged into it for grins, bought it 10 minutes later.  It's that good, I kid you not.  Even at $800 it's a bargain IMHO, compares to amps much more expensive.
PS, I have no vested interest in promoting this amp, was just really surprised.  Quintessential blackface tone.  Perfect volume for recording.  Easy to lift Wink.
Pages: 1 2 [3]  All   Go Up
Page created in 0.035 seconds with 18 queries.
