massimo santantonio wrote on Wed, 31 August 2005 07:57 |
Has anyone ever used a summing box after a hardware digital mixer? Can levels and panpots be governed by the mixer?
I have a d2424 Fostex recorder and an old Yamaha 03d mixer. I track completely outboard, and feed the mixer digitally, so I do not use that mixer's micpres and converters, just use it for song repeatability of volume levels, panpots and digital routing. I monitor through benchmark dac1. I do not want to use a computer, I like working like this, though I might wish to upgrade to 96kHz operation.
I think this is similar to ITB mixing, so I am considering experimenting with an outboard multichannel DA converter and a summing box. However the manual of my 03d mixer says I can only output digitally (via lightpipe) the 1 to 8 or 9 to 16 tracks, which in that mixer are the analog tracks (the 17 to 24 tracks are the digital ones, those fed via lightpipe by my recorder).
So I have one general question and one more specific question about my mixer. Can anyone help please? Thank you best regards Massimo
These aren't really tracks they are channels. Analog in on 1-16 and digital in on 17-24, correct. The ideal console for you, IMHO,if you want a hardware mixer and staying in the digital domain with a D2424, would be the Yammy 01v96V2 and get the MY16-AT ADAT card. You already know the basic architecture of a Yammy digi console with the 03d and although a learning curve with a few of the new features, you'll be able to mix very soon after it comes out of the box. The 96k consoles came out with the mini YGDAI's, so your CD-8 cards would not be compatible, however it has a stock 8 channel ADAT and with the card you can go 24 tracks full digi both ways at 44.1/48k. You have double channel function also on the v96 that allows 88.2/96k even going to an old ADAT 48k recorder, because it's like S/MUX or sample split, the 96k signal is split into two 48k channels, gets recorded to two 48k tracks, and than on mix down assembles the two tracks into one channel again at 96k. You can also do this with the D2424 in 48k mode. You won't be able to run 96k straight to the D2424 without going AES single wire. That would take an upgrade on the D2424 and you would only get 8 channels of 96k instead of 12 using sample split, however, before we get into a big debate over 48 and 96k, I've tested the 96k consoles at 44.1, 48k, 88.2k, 96k and no one has been able to tell the difference between all four sample rates. Blind tests involved accomplished musicians, a couple of producers and other engineers. It's this reason that I switched back to recording at 44.1k instead of 88.2 or 96k. I'm sure other peoples mileage will vary, but these are my findings on raw recorded tracks.
You've got an excellent recorder with the D2424, the FDMS3 linear format is second to none. No defragging, rock solid stable. I've been using the D's since 1996 and have never had one problem with them. I own 4 now including the D2424 (no LV)flagship model with the higher end converters. They aren't any better than the 96k Yams though and you will notice an immediate improvement over the 03d's 20 bit ADC's and DAC's, especially the DAC's have improved. I run 3 DAW's also and I simpley can not get the reliability of the FDMS3 format with Windows or Mac platforms. You probably know by now that the D Fos', do not crash. I still do live remotes to augment my mastering income and it's the most stable recording system that I have found, annie or digi for live remotes where you can't have something breaking and must get each song in one take or else.
As far as the all in one type recorders, I would stay away from them, no matter the brand, VS2480, AW4416 all of them aren't going to be as stable as dedicating the mixer to one unit and the recorder to a separate one. Great thing about the D2424/01v96V2 system is that you can keep everything out of the PC or Mac and process entirely between the console and the jog/shuttle editing on the D2424. Using Studio Manager for the big screen but no audio passes to the computer, the audio stays on the D2424 and you process on the v96 and in Studio Manager just like you would on the 03d with an added large monitor display. You also have the option of using the y56k Waves card, which has a host of Waves processors, such as the L1, L1+, L2, Ren eq and comp, Supertap, Truverb, C1 comp etc. so you can process with Waves without having to run the audio to a computer I suggest that you demo one of the 96k Yams next to the 03d, you'll hear the improvement.
If you'd like to hear some comments from people that are using the DM1000 or 01v96V2 and the D2424 check out the 01v96 group on Yahoo. You'll find many people that switched from ITB mixing to dedicated to audio only systems. Several D2424 owners that traded their Alesis HD24's in for D2424's and people that grew up on the 02r and 03d.
http://groups.yahoo.com/group/01v96/
