is there a cue sheet with the disc, that shows CD Text, ISRC codes, and UPC code?
Are they imbedded with the image? Would you add those during the new burn?
Should you extract the audio on the same burner, or a Plex?
What bit depth on the extraction? What about the burn speed?
Stereo Interleaved or Dual Mono? WAV, AIFF, or SD2 formats?
Will the two discs sound identical ? what if they don't ?
Do you leave the pre-gaps alone? are there any offsets, index markers?
Do you apply any dither on the new burn? what type ?
Should you use the same media as the master? what if it's a black memorex.
Do you proof the disc, run it thru Plextools for QC?
Do CDs spin the other direction in Australia?
There are questions, many questions, some valid, some not, some rhetorical, can you sort them out?
Just havin' a little fun tonight !
Peace Bro...
