I just went through most of the "ICs kill music" and the "addendum" threads... which do contain interesting contributions from both "camps" - but if you really look at it, the question regarding the sonics of IC circuits with regard to their actual electronical properties hasn't been thoroughly addressed after all, now has it? Either you get opinions based on subjective experience, or, when expressed in a more objective manner, they stop right where things would actually get interesting - by which I mean details (but
really EE details) regarding the electronic performance of different types of circuits with respect to nonlinear distortion.
Here and in other forums you keep reading posts that global negative feedback (NFB), especially applied in high amounts, would lessen the original fine / detail information of sound. Sometimes there is an attempt to back the claim up by stating that the distortion-compensating effect of NFB weren't sufficiently precise due to the signal's transit time through an amp stage or block; as a result, the feedback from the output supposedtly arrives at the input too late. Thus, with increased amount of NFB, the effect is supposed to get worse.
Now, (with historical exceptions) the transit time through transistor stages
alone would be orders of magnitude too short as to even affect high audio frequencies. The influence of the peripheral circuit around an op-amp as well as some history are discussed e. g. in
this thread. Two major points there: (1) Although early op-amps and also transistors had some inherently negative properties which resulted in strong limitations for a good design, these problems have been overcome with today's technology of production and application. (2) As also frequently stated, it's not the component itself that matters, it's rather the circuit designed around it.
That said, I'm going to post some observations / assumptions with a call for comment:
- When the first op-amp IC's became commercially available in the 70's, you would more or less often get bad sounding designs because some effects of NFB in audio circuitry (TIM= Transient Intermodulation Distortion, aka SID= Slewing Induced Distortion) weren't widely known and first had to be addressed. Years and decades later, these effects have been overcome, but somehow the bad reputation of the IC has persisted and become a dogma.
- Modern solid state high gain amp's allow for high level NFB, which, if applied properly, drastically reduce nonlinear distortion components. On the other hand, e. g. vintage tube amp's have less gain but also less NFB applied, which results in less suppression of distortion, where the remaining distortion components are of low order. Now my assumption would be that the difference between high and low NFB amp circuits is not characterized by some "mysterical" high order(?) distortion added by high NFB, but rather the presence of low order distortion in low NFB amp's (or, hence, the absence thereof in high NFB amp's).
- There are good and bad IC audio circuits as well as there are good and bad tube or solid state discrete circuits. In other words, being too categorical about circuit topology leads away from reality.
Lastly - I've checked up on the AES papers of 50 years plus some textbooks regarding the issue, but couldn't find too many publications more recent than early 80's... anyone know of newer sources worth reading?
Cheers,
