aivoryuk wrote on Mon, 08 August 2005 15:26 |
i'm starting to find that when mastering it's my first attempt (particulary for EQ)that i will use for the end product. if i spend too much time on something trying different techniques i tend to lose the spirit
is this the same for anyone else?? is this good or bad???
After you get some experience, you'll be able to play the tune, recogonize what eq tweak it needs or not, perform it and move on.
Is is good or bad that it takes you a long time to dial in the eq on some tunes? Neither in one case, it takes time to develop the ears so that you'll instantly recognize what eq tweaks something needs and the only way to get to that point is to practice eq'ing again and again until the you master the process. Whether or not it's bad or good also depends on your level of experience, if you were engineering for 30 years and take an hour to eq each song, that wouldn't be so good. If you are at the point where you have to eq experimentally until you arrive at satisfaction because you haven't developed the ears to immediately hear what frequencies need to be addressed, well it's a good thing, "if you remember your mistakes and learn by them".
