Both Peter and JJ are using relatively low wattage amps. That's interesting. Check this excerpt from Cary Audio out....
POWER CORRUPTS!
I believe there is a well kept secret in the circles of audio designers. Most designers will not admit to the fact that "the best sounding audio amplifiers are low-powered." Some in the industry believe that even 9 or 10 watts is too much. I have heard it said in many audio forums that, "if the first watt sounds bad, why do I want 200 watts more of the same!"
During a design effort on a new Cary Audio amplifier, I place a great deal of attention concentrated on the "overload recovery" ability of the amplifier. The ability of an amplifier to instantly recover from clipping is much more important than is commonly believed. In the power war of amplifier manufactures the mentality is focused on high and then even higher power output to solve the clipping problem. When in reality the most critical aspect is how fast of a recovery an amplifier can achieve after overload. With the incredible dynamics range of live and in turn recorded music, even 2,000 watts of power is not enough. Most of the music being listened to in an average home listening room is only requiring about 3 watts of power. It is on the transients of loud low frequency program material that tremendous signal voltages will appear at the input of the amplifier. It is in this situation that the overload recovery ability of an amplifier is of critical concern. The single-ended triode class A amplifier extols its merits in the ability to handle transients and instantaneously recover from brief or even extended overloads. The class A triode single-ended amplifier will overload symmetrically at any frequency in the audio bandpass. The triode in class A will also yield faithful reproduction of extremely low frequencies at full output levels. Power transformer, power supply regulation and output transformer design and careful shaping of the overall frequency response curve all play a very important part in the ability of an amplifier to recover quickly when overloaded. If one were to monitor the high voltage rail of a Cary Audio, single-ended class A amplifier during soft and also loud music passages it would be found there is no more than a volt or so change form soft to loud passages.
Another technical feature of a low powered single-ended class A triode amplifier is stability. A properly designed class A triode single-ended amplifier maybe operated with no load (without speakers) without damage to the amplifier, output transformer or tubes.
You will note that most of my discussion has been in the realm of vacuum tube single-ended triode class A audio amplifiers. The single-ended triode audio amplifier is by nature a low wattage device. In staying within that realm, I conclude that "High Power Corrupts!"
Of course I suppose that if you're mixing music, the "best sounding" is not as important as the most "accurate sounding", but I thought it was interesting nonetheless.
