And the thread comes alive again (maybe):
I was futzing with this over the summer, but it wasn’t pressing at the time, so I moved on to other things. Now I am back at it. I'm so close, yet so far away…
Here's where things stand:
Two Lynx I modules, both running software version V500-26L
Digi Sync box with TC in and out connected to Lynx's TC Gen and Read ports. These connections seem fine.
Studer 827 with i/o of tk 24 going to TC gen and Rdr of other Lynx. Again, this is confirmed to work. 827 isn't using a TC channel, just using the normal "audio" pathways.
Blackburst feeding into the Pro Tools' Lynx, then daisy chaining out of that unit into Video Ref of second (827) unit.
I beeped out my cable, going by the "Studer B" diagram. I note what Alan mentioned above, but it looks to me that the rehearse connection on the cable diagram is consistent with what is listed in the 827 manual - that is, pin 6. It's on the Lynx side where it looks funny - the diagram saying the Studer's rehearse pin connects to the Lynx's pin #12. Yet the Lynx manual lists pin 12 as being "Warning o/c out." Maybe I should try lifting this connection?
The other pin I wonder about is #25 on the Lynx side - the Studer diagram shows this connection as "play tally" but on the Lynx it says "reserved."
Nowhere on my Lynx document showing "pin designation" do I see a pin for "rehearse" or for "play tally" (though I do see "record tally").
I say I feel close because when I put the 827's Lynx online, the machine goes into "external varispeed." Also, it reads timecode just fine and also reads Tach. That all seems to work. I can't locate to a sync point. And most importantly, when I put it all online, the 827 does not chase.
Tools is master, so PT Lynx is online, selected as master with ref set to VSO. Put 827 Lynx online, I hear the machine click, as thought it's going to cooperate. Roll tools and nothing. I see timecode in the PT Lynx, but no love on the 827 Lynx.
I've tried all of the 827 software settings - Parallel low and high, Serial low and high. In serial, it tells me "serial err 1, serial err 2" and "tape out." But I believe it should be set to parallel anyway, which just doesn't react to the master rolling at all.
I'm looking at the "jumper array" section of the 827 manual, but nothing is jumping out at me.
I can't tell if I just need to connect one more dot or shake up the entire Etch-A-Sketch of the setup. I realize this is pretty specific, but maybe there's somebody who can spot where I am failing.
