jspartz wrote on Wed, 03 August 2005 00:49 |
Where can I order some of those jumpers?
Mouser Electronics
1-800-346-6873
P/N 517-923345-05
MFG P/N 923345-05-C
0.5" Green 200/ Pack
3M Jumper Wires
As far as the problem as stated... I wonder if it is not a bad contact on the other side of the "mother board" (back plane). The connection point where the channel connects. Give it a shot of deoxit. Also clean the 1/4" send/return/insert connections for that matrix channel.
Jason
I guess they have the good stuff here. What would be the best spray to use? Deoxit? Is that the brand name?
I believe you may be right about that being a problem as well since I could wiggle any channel seemingly at random and the left channel would come back.
I also found that cleaning the matrix channel outputs is key.
I ran through the whole schematic and got to the outputs and thought...hmmm....
Also I now have two bad channels I need to troubleshoot. I have no idea where to begin.
I did pretty good on the resolder job I guess. It's 0305 in the morning and I am done....four hours, with breaks to read the REP.
Tik
