Author Topic: Instrumental (TV) Tracks ?  (Read 812 times)
Jerry Tubb
« on: August 01, 2005, 02:25:58 am »
For No-Vocal (TV) and Instrumental Tracks that often go with a pop mastering job.
I usually print those immediately after doing the vocal version, while the EQ is set.
Only takes a few extra minutes.
Today I went back and looked at my notes, to master the Instrumental tracks for a record we mastered about a month ago. Having those notes made it go easily.
Sometimes I'll bring the level down a dB or so, to make the tracks playback a little easier, on whatever format they end up on.
Anyone doing anything different ? Anyone get many of those to master ?
Terra Nova Mastering
OldSonic
Re: Instrumental (TV) Tracks ?
« Reply #1 on: August 01, 2005, 04:01:57 am »
JayTea wrote on Mon, 01 August 2005 10:25
 We do a lot of TV-versions (called "minus one" here). The same as vocal version, but less compression - PA and TV engineers ask some more peak-to-rms ratio, they need some room for vocal.
Andrey Subbotin
bblackwood
« Reply #2 on: August 01, 2005, 05:56:27 am »
Run them the same here, typically...
Brad Blackwood
euphonic masters
Bob Boyd
« Reply #3 on: August 01, 2005, 01:33:52 pm »
Typically the same processing here.
I usually run the TV and Instrumental versions on a different session (and usually a separate invoice as well).  That way, I can turn the project quicker, the whole project can go through the approval process, and I'm not changing 3 versions instead of one if there are tweaks.
It also gives the client a better view of what the project cost separated from what the tracks added to the invoice.
Bob Boyd
ambientdigital, Houston
http://ambientdigital.com
Twitter: @bobboyd
