Author Topic: 1176 on drum room mics YES, but lots of cymbal rise  (Read 9990 times)
permeke
« on: July 14, 2005, 04:48:27 PM »
I love my 1176 comp. on the drum room mics squashed to death, but then I have so much cymbals in the output, more than any other instrument of the drumkit.
Is that the nature of the 1176 ?
any tricks you guys use to avoid this ?
Fibes
Re: 1176 on drum room mics YES, but lots of cymbal rise
« Reply #1 on: July 14, 2005, 05:19:52 PM »
I tend to cut some high shelf on all room mics no matter what the compressor. YMMV
Fibes
"You can like it, or not like it."
The Studio
  http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewArtist ?id=155759887
http://cdbaby.com/cd/superhorse
http://cdbaby.com/cd/superhorse2
Rob Darling
« Reply #2 on: July 15, 2005, 07:26:24 AM »
The 1176 is a fast compressor- even the slow attack and release are relatively fast.  That said, like any other compressor, fast attack, fast release, and you get the sustains up next to the peaks.  In a drum kit, the cymbals have a gazillion times more sustain than any other part, so they end being as loud as everything else.  That's how she goes.
____________________
rob darling
rob@robdarling.net
www.robdarling.net
j.hall
« Reply #3 on: July 15, 2005, 08:58:44 AM »
slow down the release time.
permeke
« Reply #4 on: July 15, 2005, 01:22:47 PM »
j.hall wrote on Fri, 15 July 2005 14:58
Then I lose the 1176 sound  Confused
j.hall
« Reply #5 on: July 15, 2005, 01:36:37 PM »
um......i'm confused
DJC8902
« Reply #6 on: July 15, 2005, 01:47:45 PM »
Actually,  permeke is absolutely right. The slowing of the release time completely takes away that amazing pumping affect of the 1176 on drum sounds...which makes it such a great choice to crush room mics with. I agree with FIBES, try and low pass some of the swish out of the room mics and meet it in the middle. Its worth it in the end to have them sounding a little messy, the cool outweighs the messy by a million!
j.hall
« Reply #7 on: July 15, 2005, 06:38:06 PM »
i disagree completely.....i've used tons of 1176's (and i'm no seasoned pro)
backing off the release time a tiny bit at a time to get the cymbals to tame down still yields an 1176 sound.....you're pumping the sound through the same box....it's got the same tone
so, i'll remain confused....
bjornson
« Reply #8 on: July 16, 2005, 09:43:45 AM »
The real solution is to educate the monkey with the stix.
Let him hear what the result would be if he could only back off the brass while still wholloping the skins!
lord
« Reply #9 on: July 16, 2005, 10:49:02 AM »
I have a real question. Why are rock cymbals so freeking heavy and loud in general?
They are overpowering when recording.
They're too loud in the room when rehearsing.
They ring WAY too long.
Drummers always hit them too hard anyway.
The only advantage is that they don't crack.
Why why why?
If you suggest lighter cymbals to most guys they look at you like you just suggested they should play in lace panties and high heels. So my theory is that it is all a big dick thing. Hmm?
Or is it that they sound about right with a 25db foam ear plug ? Maybe the solution to the original poster's problem is to place the room mic in a 50 piece carton of ear plugs?
jgehring
« Reply #10 on: July 16, 2005, 03:26:22 PM »
I hate the heavy gong-like cymbals too, which is why I keep a set of thin ones in-house.  Just tell the monkey that while he made a brilliant choice buying those 1/2" thick garbage can lids that sound TERRIFIC live and that only the manliest of men could play, the thin ones are your "studio secret weapon" and that you won't tell anybody.
drumsound
« Reply #11 on: July 16, 2005, 03:45:38 PM »
jgehring wrote on Sat, 16 July 2005 14:26
Laughing
The cymbal makers keep making them thicker because the amp maker makers keep making amps louder and more distorted.  The drummers buy them so they can hear the cymbals over the guitars.  The guitar players then buy louder, more distorted amps so they can hear guitar over the cymbals.  So the drummers buy thicker cymbals...
Rivers
« Reply #12 on: July 16, 2005, 09:13:52 PM »
Definitely true about trying to get heard over guitars.
I was doing some roughs for a band last night and on one particular  chorus the drummer was displeased with how his open high hat bashing was overriding everything else in the mix.He  kept looking for ways to bring down the high hats but they were in all the mic,etc.We managed to get it better but I think/hope it reinforced that the big problem was the way he was bashing,not the mics,room,setup,etc.
I also have a theory that most drummers don't really have a great idea of what their kit sounds like 10 feet away in a room...probably the only time they've heard it was on a recording or through some jacked up live monitor mix,
One more reason a little preproduction can be a good thing,I guess.
Smell the Magic
http://www.katp.com
pg666
« Reply #13 on: July 17, 2005, 03:07:20 PM »
try putting the room mics on or near the floor to reject some 'cymbal suck'. actually, i don't know if it rejects high end or just brings up the low end 'boom' on drums, but it helps.
personally, if i hear too much 'sucking', i just back off the comp.
j.hall
« Reply #14 on: July 18, 2005, 07:56:45 AM »
moving the mics down to the floor just eliminates some reflections bouncing around the room, especially off the floor.  that technique is best suited for omnis.
Page created in 0.066 seconds with 19 queries.
