> I discovered that the first "variable Gm" (aka "Delta
Audio is a vocational affliction
"there is no "homeopathic" effect in bits and bytes." - HansP
« Reply #30 on: August 11, 2005, 02:20:48 PM »
Tek 577D1. What do you think a fair price for a storage (and non-storage 577) should be? I see the D1 going for $2,000 USD+ , but I'm guessing a shrewd engineer can find them for less? What's the D2 worth? Thanks, Justin edit: Another one here: http://cgi.ebay.com/Tektronix-577-177-Curve-Tracer_W0QQitemZ 7537304581QQcategoryZ1504QQssPageNameZWDVWQQrdZ1QQcmdZViewIt em
« Reply #31 on: August 12, 2005, 11:45:09 AM »
I was bidding on several 577d1's in the $500+ US range on Ebay. Then I found one for $375US that had a busted a/b switch handle I fixed in 10 mins.
They go for more like 500-1000 US from my experience.
D2's are more. But high voltage option is needed in either one.
edit: the top one ain't a D1 it's a 577 non storage. too much.
it will say "D1 Storage" in the upper right corner over the intensity knob. this one does not.
« Reply #32 on: August 12, 2005, 12:00:17 PM »
Many thanks for the advice Larry.
I was asking because a local dealer has a 577 in stock, and they claim it's fully working / serviced... I've bought from the dealer before, and they're usually ok for haggling, so I thought it best to get an opinion on the price...
With the 570 not being an option, are there other curve-tracers worth having that are not Tek? Did B+K make a good unit for valves? I'm guessing there are probably units around from the likes of AVO / GEC / Marconi etc, although the costs of restoration may be prohibitive I guess...
I should clarify that I'm only looking to match / test small-signal valves for front-end apps, not power-tubes.
Cheers, Justin
« Reply #33 on: August 12, 2005, 02:24:24 PM »
Well guys, with regards to the trademark issue related above, as far as we know, we were the first company to make a dynamic limiting rack mount product which was called the "Variable Mu" Limiter Compressor and so we trademarked that product name to be ours in order to protect our mark the same as I trademarked "VOXBOX" "ELOP" "LANGEVIN" "MANLEY" "STARBIRD" "SLAM!" et al. Those are our product and brand names. Trademark law protection dictates that I can't start manufacturing an audio product called "The Manley Distressor" no more than some other company can start making one called the "[insert company name here] Variable Mu".
Yes we can all still talk about variable mu dual triodes as they were called in tube manuals, and yes, "variable mu" is still a swell engineering term as discussed above. Yes of course there were many other limiters throughout history which used similar methods as ours to achieve limiting. Obviously we built upon this history, literally. We never claimed to have invented the method or the concept of this type of limiter. We were just the first who applied those two words "Variable Mu" to the faceplate and called our product that. The trademark means no other company can call their audio signal processor product a "Variable Mu". That's our name that we applied to our box in 1993 and later trademarked. That's it folks.
Besides this aside, this is a great thread....
« Reply #34 on: August 12, 2005, 02:57:44 PM »
waves from the east!
« Reply #35 on: August 12, 2005, 03:31:59 PM »
Quote: | I should clarify that I'm only looking to match / test small-signal valves for front-end apps, not power-tubes.
Triodes only.. Tektronix is the only one worth messing with. And the 577 has 1600v @ 20 watts, so it's possible to launch a tube right out of it's socket with too much throttle. =) For pentodes, you can fashion a screen supply too. Use pomona plugs and protoboard to make a tube socket jig. And it has a chimp-proof hv interlock you need to push on that the original jig has a pin for. I have dual jigs for all my fave tubes. It was easier than jumpers. Hint: 4 tube sockets per jig allows you to compare different tubes on each side and each sides' sockets are just wired in parallel so the unused socket becomes inert. So my main jig can compare 6386's to each other or 6BA6's to each other or 6BA6's to 6386's etc.
« Reply #36 on: August 13, 2005, 12:29:00 AM »
> The variable-mu valve is probably from the late 1920s or early 1930s. I know that they were commercially available by 1933. The full development was prompted by the superhet receiver but I have a feeling that manual bias changes were applied to earlier TFR receivers.The core problem (40dB-60dB range of radio signals) is the same TRF or superhet. But TRF was a fussy thing anyway, so manual gain control was tolerated. Superhet allowed one-knob tuning (good TRF had three tuning knobs) so it began the trend to "dummy" radios that any fool could operate. The oldest way to change gain was to reduce filament current. This not only killed Gm, it made your batteries last longer. But it had the same flaw as grid-bias control: for large reduction of gain, the plate current times the load impedance gets so small that the output overloads. Antenna potentiometers were sometimes used. But Cunningham's data for the '01 (their number CX-301-A) says "Volume control ... variation of either the grid bias or the plate voltage...", no mention of filament control. (This is stated to be a "storage battery" tube, but at 5V heat they are assuming a 4-cell 6.3V battery and a rheostat that you adjust to keep an even 5V glow as the battery runs down from 6.3V to ~5V.) The type 35/51 is a fairly old "Super-Control" tube (another phrase that someone should trademark) and the 1937 data (the tube is older) shows grid voltage needed for 37dB gain reduction (unspecified current, but obviously way too small for useful output with anything other than a tuned circuit). That sheet references a page 15; this seems to be the page with a hasty note about super-control tubes. BTW: this page says "variation in amplification factor", which could also be spelled "Variable Mu". Prior art is no bar to trademarks: the word "coke" was widely used for cooked-coal and cocaine products long before a soft-drink company registered it. In fact they were reluctant to call their brew "coke" because of the Drug Act (if it contained cocaine, it was illegal; if it didn't, it was misleading) but "had" to register it so that no other drink company could use it and be confused with Coca-Cola. "Variable Mu" was apparently up for grabs when EveAnna applied for a Trademark. A specific implementation of "Variable Mu" might be valid as a Design Patent. Clearly there should not be an Invention Patent on "Variable Mu" at this point in time (though the current US Patent Office is liable to approve anything and let you fight it out in court). In all these old notes, know that "Volume Control" does not mean what it did later. Early radios had tame audio stages that were run wide-open, no audio gain control. With the rise of the dummy superhet/AVC radio, and with better audio stages, the idea became to let AVC action keep the detector output up as close to 10V as possible (by AVC-reducing RF IF gain) and then use an audio potentiometer to reduce audio gain to the desired listening level. In local reception, it keeps all stations in/around town at similar level, so you can (one-knob) scan the band without deafening yourself. (In short-wave use, a single station will fade in and out as the ionosphere wobbles; AVC does act to keep a constant volume with fading.) > I trademarked ... "STARBIRD" ... et al. Those are our product and brand names.In the audio racket only. If you started making custom cars (you'd be good at it) and called them "Starbird", you would run right into Darryl Starbird. I don't know if he trademarked his name, or if that would bar your use of it in his field; I leave that to lawyers. Even in the audio racket only, you are only a few notches away from being razzed by the Songbird hearing-aid company. Hey; hearing aids are audio. And modern hearing-aids include limiters and equalizers. But you didn't step ON their name, and hearing-aid customers are unlikely to confuse a hefty Manley for something they can stick in their ear.
« Reply #37 on: August 13, 2005, 09:31:36 AM »
Thanks for the clarification on variable mu as a generic technical term vs a unique product name, EveAnna. I get it, and will type with less fear now =) .. even though PRR says it's a flawed term. But I suspect over time, one could save a few engraver bits by not having to keep engraving the word 'transconductance" over and over. Wasn't that Kraftwerk's 2nd album "Transconductance Express" ? Hey PRR, what about pentagrid converter tubes? Ones with a remote cutoff grid, and a normal one? Audio goes into the straight grid and control into the remote cutoff grid. Anyone done that? and would they mix like a dual gate mosfet and create artifacts? Eh? Quote: | If you started making custom cars (you'd be good at it)
Edit: If Manley made a car, I'd buy it in a New York Second. Imagine a purplish billet of streamlined aluminum with 4 black tires and some windshields.
« Reply #38 on: August 14, 2005, 06:05:34 AM »
Larrchild wrote on Fri, 12 August 2005 20:31 |
Triodes only..
Thanks again Larry. J
« Reply #39 on: August 16, 2005, 08:05:36 AM »
vanimal wrote: | Besides this aside...
...I'm still trying to figure out how you do that! Keith
MDM (maxdimario) wrote on Fri, 16 November 2007 21:36 | I have the feeling that I have more experience in my little finger than you do in your whole body about audio electronics..
« Reply #40 on: August 16, 2005, 04:42:39 PM »
I've seen it proposed. I've even seen a plan, though not detailed.
One monster advantage is you don't need a floating transformer winding to get both audio and control on the same grids. Couple chips would do great.
There's always artifacts. The minimum-artifact approach for speech/music is usually fast attack and slow release. That still clobbers the first over-level wave; but that is inevitable unless you can see into the future. (There is a class of limiters with a delay-line so the control can preview the audio and act a little ahead of time.)
« Reply #41 on: August 16, 2005, 09:07:26 PM »
Quote: | There's always artifacts.
Right-on, but I was thinkin if you combine 2 signals into a common gate its not the same as if you combine 2 signals into 2 gates of a dual gate mosfet. It acts more like an rf mixer due to additional non linearities. f1+f2 f1-f2 f1+f2-f1+f2 ,lol all that. Easy enough to breadboard. I'll get back to ya.=) Quote: | that is inevitable unless you can see into the future
Well, I just need to copy my vocal track in PT and slide it a few ms early and drive my control amp from that. Ain't no big thang!
« Reply #42 on: August 20, 2005, 07:49:14 AM »
Larrchild wrote on Fri, 12 August 2005 16:45 | I was bidding on several 577d1's in the $500+ US range on Ebay. Then I found one for $375US that had a busted a/b switch handle I fixed in 10 mins.
Larry, How do you confirm one has the high-voltage option? What if you bought one without - does it have to be a factory option? What about the other options - I assume the 177 fixture isn't essential? Thanks again! Justin
« Reply #43 on: August 20, 2005, 11:08:52 AM »
Part of the fairchild sound was derived from the fact that it's almost impossible to get truly linear sound out of it.
the good thing about the fairchild is that it is a one-stage design.
It does amplification, gain reduction and line driving all in one stage of 4 parallel 6386 tubes.
this makes it direct sounding, distortion aside.
If we focus on the distortion artifacts, it distorts differently depending on the amount of gain reduction, and it is a mix of all the 4 tubes' non linearities, as well as being class-a push-pull which means that some of the low-order distortion cancels out, but not completely because the two sides are never truly matched.
grainy agressive sound.
with two tubes, you can match the characteristics better, and end up with a cleaner sound, but then you've got to put a line driver after the GR circuit and that adds it's own kind of distortion as well.
the fairchild 660 was a unique box.
« Reply #44 on: August 20, 2005, 08:50:49 PM »
Quote: | How do you confirm one has the high-voltage option? What if you bought one without - does it have to be a factory option?
Well, I should say its handier to have the high voltage option. Look and see if the voltage knob goes to 1600v. If not, find a tracer that has at least has 400+ The 177 is the general test fixture and probably the one you want. Also the most common. avoid test fixtureless units. Quote: | the good thing about the fairchild is that it is a one-stage design.
It's also a no-feedback amp relying heavily on push pull cancellation of distortion products.
« Reply #45 on: August 21, 2005, 08:58:22 AM »
Yep.
but all vari-mu GR circuits are no feedback.
only the post GR line drivers such as in the u176 or Ba6a etc used feedback.
others, like some collins, altec etc. used no feedback at all throughout.
But yeah... a big part of it is the sheer simplicity of the audio path.
