maxim wrote on Sun, 26 June 2005 09:06 |
tom wrote:
''drooping' freq response in the top or bottom..'
is more better than less?
is bass different to treble?
i have left my mixes intentionally dark, because i think the eq at the mastering suite is better than my laptop stuff
I had a client who was used to getting terribly brightened masters from another mastering engineer, come to me with mixes that were much too dull in the top. He figured I'd do the same. There was only so much I could do to help his mixes. Raising the top to help the cymbals and the air, past a certain point made the vocals sound strident and the electric guitars sound thin. It was a difficult situation and the end result was a compromise. He vows never to do that again!
My advice is that you go for a mix that is as well balanced as you can make it, make the high end sound as right as you can, because the less correction the mastering engineer has to make the less the overall mix will change and the less chance that instruments and vocals will change their timbre. Adding highs to an overall mix is definitely not the same as tweaking the tonality of individual elements within the mix, because you then, consciously or unconsciously, change the level/balance of the instrument to compensate for the effect of your tonal changes. We cannot do that in the mastering, generally.
I understand your reasoning about the EQ at the mastering suite being better, but overall EQ is not the same as mixing and the more EQ that is applied in mastering, the more the intent and feel and relationships of your mix will go out of whack.
