hei zetti:)
this is a review to build on:) THANX MAN!
My biggest problem now: my mixing/recording-room sucks a lot. I have early reflections and it's very hard to mix something. also my monitors sucks a lot (spirit absolute 2). Yeah all the people tell you, if you are experienced you can mix on computerspeakers, but I can't. so Bad room, bad monitoring and very little expirence.
And I am the tracker, producer, mastering eng... blah, that sucks. The band couldn't afford to master the bitch so I go out my cubase with all the tricks done I have.
second problem:
bad souncard. Terratec EWS doesn't make the job. I have to pump up the lowend because there is only little recorded. Also it sucks on transients so I have to get things in front with dominion.
I don't know where to start upgrading instead of my knowledge;)
Quote: |
after two years my metal mixes sounded far worse than yours!!
puh, my ego is getting better:) thanx zetti.
so for demoproduction is this sufficient? if I compare my mix to the other local underground-swiss-metalband-cdmixes It's ok. I don't know how demos sounds in your area.
Quote: |
it's an artform.... and it takes time....
jap, and maybe this is the "lifelong learning-thing":) maybe it takes a littlebit longer here, because I only mix 2 times a week (because I have a 7 to 5 job and 2 bands). Maybe I should mix more.. hum..
cheers and thanx guys:)!!!!!!!!!!!!!!!!
