Yiannis wrote on Mon, 06 June 2005 05:20 |
I wonder what will happen using 110ohm cable instead the normal 75ohm for SPDIF. are there any artifacts? differences on sound quality? How would you check it?
Someone mention a bitscope to test it,but I can't configure it out.
Thank you
Yiannis
For short cable runs you can do just about anything. A bitscope won't tell you how stable the interconnection is. All us mortals can do is listen for glitches and maybe if you have a lock light look for a steady lock light.
If you wish to mismatch connectors or terminations or cables, just keep the cables very short and you PROBABLY will continue to have a stable connection. Jitter will likely go up, but this is irrelevant as long as you are not clocking a converter to this signal. In other words, as long as you are making a digital transfer and processing digitally.
As for AES versus SPDIF software, way back before 10-15 years ago when pre-emphasized sources were more common, it was possible to misread the emphasis bit, but nowadays nearly EVERY receiving piece of sofware ignores the emphasis bit and assumes it is turned off. So you can feed SPDIF protocol into an AES receiver and vice versa with no troubles.
As for the hardware issues, I cover a lot of those tricks (how to get an SPDIF source into an AES receiver) in my book. And there are schematics floating on the Internet.
BK
