Today I had to master some hiphop tracks and with my new insight that it's better to do less I was finished suprisingly fast, normally I'd spend a lot of time trying to make the mix into something it's not. It's a good thing I charge by the track
So I spend the rest of the afternoon trying to come up with the definitive master of Motionsickness and I ended up with something that sounded amazingly close to the original mix.
What makes Motionsickness so hard to master is that there's almost no separation between the instruments. I find a Trevor Horn style mix, where every instrument has it's own place in the mix, way easier to master. It gives you more space to navigate, if everything is so connected there's almost nothing you can do without messing up something else.
While experimenting with different L2 thresholds I noticed that the transients contain a lot of depth info. When I cut off 1.5dB of the snare transients without messing with the body of the music, the percieved depth decreased. I always thought that depth info was in the low ambience levels. Reminds me of the difference in depth I heard with the Limiter tests a while back. Does anybody know how transients relate to percieving depth?
It was also very refreshing to listen to a master without any limiting at all, I almost forgot how that sounded. I'd better not get used to it or I'm gonna be very unhappy listening to music.
You live and learn. Looking forward to the WOMP.
