Author Topic: Apogee vs. Apogee  (Read 1655 times)
Yellowguy
Apogee vs. Apogee
« on: May 09, 2005, 11:45:52 am »
There has been some threads on converters lately, but my searches have not been fruitful, regarding my particular qeiry.
What I am curious about is if anybody has compared Rosetta 800's to the 16X models, and what may be the differences. (yes, I'm aware that one is 8 in 8 out and the others are.... well you get my point)
When checking their website, the only difference I can seem to find, is that they brag more about the clock in the AD-16X. Does the Rosetta have an inferior clock?
What would be other differences?
Bottom line, which should I get? BTW I don't want to hear it about the Prisms etc, Apogee is as expensive as I can go.
Regards
Marco Manieri
PaulyD
Re: Apogee vs. Apogee
« Reply #1 on: May 09, 2005, 12:58:42 pm »
Late summer last year, I called Apogee tech support and asked if connecting a Big Ben to the word clock input of the Rosetta 800 would yield the same sonic results as the AD-16X/DA-16X devices. They said no, citing improved analog filters in the xx-16X devices. They also make it clear that the C777 clock in the xx-16X devices is the same clock used in the Big Ben and is superior to the Intelliclock of the Rosetta devices.
Paul
Yellowguy
« Reply #2 on: May 09, 2005, 01:57:28 pm »
PaulyD wrote on Mon, 09 May 2005 18:58
Paul
Thanks for the info Paul. Do you know if it actually sounds any better?
Marco
PaulyD
« Reply #3 on: May 09, 2005, 02:51:07 pm »
I've never compared a Rosetta side-by-side with the xx-16X devices. fwiw, I went with a Mini-Me and a DA-16X and have been very happy with both. They were just a gigantic improvement over the built-in converters in my MOTU 2408 mk II.
Paul
gwailoh
« Reply #4 on: May 09, 2005, 05:05:21 pm »
Here's what Michael Cooper wrote in Mix (http://mixonline.com/mag/audio_apogee_adx_dax_2/index.html):
"With an A-weighted dynamic range of 120 dB, the AD-16X's converters conveyed a strong sense of realism. In A/B tests, they provided significantly greater depth, focus and high-frequency detail than the Apogee Rosetta 800's A/D converters. The Rosetta 96's A/Ds, on the other hand, provided a hair more depth and fluidity in mids and highs than the AD-16X's converters. The differences were extremely subtle, but sounded as if the mics were moved a couple inches closer to the source (without added proximity effect) from a couple feet away to reveal a tad more nuance."
Hope this helps.
snakecained
« Reply #5 on: May 10, 2005, 08:35:17 am »
I would say the 16x are 5% better than the Rosetta 800.
Small, but noticable with the right signal path.
