Hello all,
I've always wanted to respond to that trend but was kept to secrecy. It doesn't matter anymore, so I will give you more information on the PCM3052 (and it's new revision the PCM3052A).
It was a really wrong guess to think that this little beast was a low cost, mass market chip. It was actually designed as a high(er) end product, and had nothing to do in a computer- that's why it was so fun to squeeze it in. I have seen MANY pro-audio gears that didn't sport a DAC as good as the one you are talking about. What makes it mass market (and cheap) was the high volume at which Apple buys it, NOT the quality of the part. For information, the DAC supports 192KHz, while the ADC is limited to 96KHz.
Regarding the simple topic DAC, ADC or codec, it really doesn't matter- all those devices are built using a 0.35uM process, so the die is pretty small. The only time where integrating both ADC and DAC on the same die can be a problem is when asynchronous operation is required beat tones can appear. In the case of the PCM3052, ADC and DAC are synchronous so it really doesn't matter. For the note, there are countless chips on the market that sports both ADC and DAC, but only one section is bounded out, and available to the user. It just outlines that die area is not what you pay: IP is what you pay! It is also very common with single opamps: it is actually a dual opamp but one of the chips is disabled,,,
Analysing the chip, you will notice that the DAC section is of much better facture than the ADC section. The integration of a few features in front of the ADC allowed for a better integration in the Mac, especially the ability to switch between the stereo analog input and the microphone input. The mic input is only an inverting opamp with high gain, then switch, then PGA. The integration of the PGA allow for a good matching of the gain range. The ADC is a single bit, oversampled ADC with pretty good quality FIR downsamplers. It is the classic Burr Brown ADC.
The DAC is an 8 level quantizer with a 4th order modulator. SNR is around 104db(A) and THD is at -93db. Not bad for a 2001 product. Not looking at numbers, it is the sound of Burr Brown converters that made them famous- and it shows. Listening to the PCM3052, the "slam" is really good, and it kept a soft but detailled sound. I defy anyone to find a chip used in a computer that sounds that good. For the note, the same exact DAC structure was used in NAD CD players, with a very similar sound... NAD is usually pretty critical in the choice of their chips.
Of course the DAC is not directly connected to the output jack- a stereo headphone amplifier is used. The selection varies depending on the machine considered, but all of them are on a Bi-Cmos process, with bipolar input stage. Bipolar input stages are much better at maintaining low noise at low power. All of them are also using a "charge pump" to remove the need for coupling capacitors- the only coupling cap is BEFORE the amplifier, where it is small and can be chosen of better quality. Using coupling cap on the output would force the use of high CV capacitors (at least 100uF) that have much more impact on sound...
So there- the PCM3052 will disappear of the mac now that the system is Intel based. And it is a shame- what replaces it is certainly not as good....
For the note, TI made the datasheet of the PCM3052A available on their websites if you want to have a look. Please note that quality of the filters and such- we've seen way worse, and very often!
