Ronny wrote on Wed, 27 April 2005 15:12 |
Question: SPL is relative to distance and the closer you are to the speaker or headphone speaker the higher the SPL, so isn't this still all gain relative, gain meaning how much power you have to apply to get x SPL reading.
um, sort of. the inverse square law applies here.
3dB rise in volume by doubling the power to a speaker, a 6dB loss in volume by doubling the distance the listener is from the loudspeaker.....see the dilema here?
if you are 100 feet away from a giant loudspeaker cluster at a concert venue, and your meter says 100dB Un-Weighted, you'll have to walk 50 feet closer to the cluster to get a reading of 106dB (this is assuming the acoustical environment is the same in both positions).......so, 25 more feet and you're only up to 112dB, 12.5 feet, 118dB.....
here is what you are missing in this.
headphones are right on top of your head.
Brad never said that headphones are ALWAYS louder then any speaker system known to man
you are confusing overall "max spl" with potential.
Quote: |
In that case wouldn't headphones and loudspeakers have the same amount of SPL relative to watts?
NO. that's exactly my whole point. every single speaker made is different. and this is why manufacturers (the good ones at least) publish their sensitivity tests. the 1W/1M (one watt, one meter) numbers are crucial to this whole conversation. you have to understand exactly what that number means and it's implication, to understand why your thought process is off.
the point is this.
a pair of headphone strapped to your head (cause no one will ever listen to cans any other way, just as you won't strap a pair of questeds onto you head) have the POTENTIAL (key word here) of being much louder and more damaging to your ears,
at lower power levels then any loudspeaker on the planet (at least that i've come across......
Quote: |
I enjoyed your explanation, but I'm still confused on how a little speaker can move more air molecules than a speaker 10 times larger.
proximity, and potential.
my questeds are having to move the air in the entire room to reach levels that my beyers only have to move directly on my head pumping sound directly into my ear canal.
this is why most headphones have a lower sensitivity then loudspeakers.....they're actually trying to protect you from having blood run down your neck.
