merrymerry wrote on Sat, 31 October 2009 21:39 |
In samplitude and sequoia in the "general" settings there is an option to lower all mixer strips by 6, 12 or 18 db!!
Samp user here.... That's very easy to do, basic digital math, each time you shift data to the right, you attenuate by 6dB. But in the end, you loose the LSB's, so the improvement you get in
digital resolution when tracking is lost in this downscale operation. I won't rise the subject of whatever headroom issues, because it has been beaten to death, and each one camps on their position.
Quote: |
Thats right... you can record so you are peaking at -3 db to get the fullest possible recording quality....
"fullest possible recording quality" is an issue that involves more than one parameter. Bit depth is just one of these parameters. Now, if your analog equipment starts to fart out at +12dBu, you may not want to record at -3dBfs (equivalent to +15 to +21dBu in analog.
Quote: |
Bobkatz , maybe you could suggest this to your customers that use samplitude or sequoia?
Warm regards, Merry.
I don't think it's anybody's role to advocate an MO that may well be suitable for you and your configuration, and completely inadequate for someone else.
I think you've done the right thing: making members aware of that feature (that I personally don't use).
