Well, the mix i've been using is a fairly standard pop song with no vocals, only drums, bass guitar and electric guitars, the plugins used are EQ and delay, no compression (does compression behaves differently when changing -6dB on signal input even with the same value applied to threshold?*). I repeated the test, this time i didn't even care if the mix sounded good at all, i tried to get the summing of tracks as hot as possible (on the mixdown with no trim plugin on every track the master fader even peaked once!).
Still, when checking the -6dB mixdown with the hot one the only difference between them was that evil peak on the hot mixdown, other than that, they were mathematically identical!
It's truth that i'm not using compression and the added HF on some of the tracks is rather moderate, but shouldn't this be enough to start getting some differences when comparing these mixdowns?
The recordings were all made with apogee converters not going any further than -5dB on input!
Paul, with this tests i'm not trying to prove you wrong, believe me on this, i'm only trying to understand your statement trough practice, for all our best interest it is very important for us to understand our tools as best as we can!
*- i did try this same experience using compression, in this case the difference was very noticeable, although it seemed more like a compression problem...
Best Regards
Zed
