Quote: |
Hmmm--do you think I can shout loudly enough to be heard in another thread? HEY, you folks who're talking about how to test for audible differences among cables--...Unless you limit yourself to one variable at a time, you'll get results that anyone and everyone can interpret differently--supposedly the situation that you wanted to improve on in the first place.
I appreciate the thought, David. Be assured that I would not accept a comparison test for audio equipment any other way: audible impressions, especially those of lesser players like cables or capacitors, are so fragile that any additional "noise" on the brain from more than one variable at a time kills the ability to discriminate altogether.
Please continue to add your insights to the exciting cable thread (over 2000 happy customers in a week!)
To the subject at hand:
Congratulations, David, for an excellent sales job for transformerless mics without any (overt, at least) appearance of bias on your side!
But, your seemingly logical deductions are not convincing me:
Quote: |
Isn't it obvious that there's more difference within each group (TL or T) than there is between the two groups? Whenever that's the case, any generalizations that you hear should be taken with a grain of salt at least.
You give no data or evidence for the obviousness of your subjective observation, therefore I treat (and identify) it as your personal, subjective, opinion.
You then elegantly conclude from the "obviousness" of your opinion to a generalization, which, objectively, is based, again, solely on your unproven and undemonstrated opinion.
If you are not an aficionado of transformer-coupled mics, (which I what I suspect) then shouldn't you state that up front, rather than give seemingly equiponderated, objective sounding advice, while subtly leading the questioner down the path to your personal preference?
For the record, once more:
I have never heard a really heartwarming, musical microphone without transformers (other than the elegant Schoeps Colette designs which wisely avoid solid state processor overkill by relegating the "transformerless", i.e. transistorized, portion of the circuitry to the very tail end and then to just two solid state devices run very conservatively, leaving the actual audio processing relatively clean.)
The same cannot be said about most other TL designs which, in my opinion, often sacrifice audio excellence for the sake of cost savings and then buff the remains with "cool" looking, but for most applications irrelevant, head room specs.
P.S.: I found some faulty logic, expressed somewhere else in this thread, (not by you, David) To paraphrase:
"There are lousy T- mics and excellent TL mics, so we should not generalize..."
The buying public depends on generalized identifiers for its purchasing decisions.
So, generalize, I'd say, but do it fairy:
Compare the 'best' (defined as most desirable, by historic standards) TL designs to the best T designs, rather than throwing in some dogs of mics to prove a pointless point.
Kind regards,
