Author Topic: Anyone ever had this guitar / tuning problem?  (Read 4485 times)
ALLEN WRENCH
« on: April 06, 2005, 09:02:24 am »
I've got a bizarre guitar situation going on right now.
I'm on the last song of my record and I can't get the guitars
to sound tuned to the bass.
On tuners (Peterson strobe and 3 others) they look ok, but just don't sound right.
After further investigation I noticed that when you play one note on one string,
on guitar, it sounds out of tune… WITH ONLY THE ONE NOTE PLAYING.
Has anyone ever had this problem with a guitar?
You may not be interested in Dr. Wrench,  but Dr. Wrench is interested in you.
heinz
Re: Anyone ever had this guitar / tuning problem?
« Reply #1 on: April 06, 2005, 09:08:53 am »
sounds like they need to be intonated.
heinz schuller
heinzmuzik
covert
« Reply #2 on: April 06, 2005, 09:27:31 am »
Strings can have weird overtone series for any number of reasons, and will then sound out of tune with themselves.  Try changing the strings.
Also, when tuning for a fast song, you may want to tune so that the settle down period is shorter than for a slower number.  Similarly, the settle down period for bass is longer than for guitar, so they may sound sharp when tuned properly.
ALLEN WRENCH
« Reply #3 on: April 06, 2005, 09:29:36 am »
Remember, this is ONE guitar playing/holding one note… NOT two guitars playing the same note.
The one note sounds like it's out of tune, but it's the only thing playing.
It’s really bizarre.
I was suspecting the magnetic pull of the other pick-ups causing some sort of oscillation.  This is a Strat with EMG humbucking rear, mid and neck position single-coil sized pick-ups.
ALLEN WRENCH
« Reply #4 on: April 06, 2005, 09:37:39 am »
About the strings, my guitarist plays a kind of weird set… real heavy bottoms and normal tops.
First-E:  10
Second–B:  13
Third–G:  17
Fourth–D:  36
Fifth–A:  52
Sixth-E:  60
Oh man, they’re the Zakk Wyld signature series!  What a dirt bag.
Eric Rudd
« Reply #5 on: April 06, 2005, 09:39:20 am »
ALLEN WRENCH wrote on Wed, 06 April 2005 14:02
Are you saying that the one string is out of tune with itself, or as compared to the bass guitar?
As someone mentioned the guitar might need to be "set-up." Intonation, nut and/or saddle adjusted, etc.
During my time working on guitars at a music store occasionally (rarely) you'd get a string that would generate a "wolf tone." (I don't know if this is the technical term, it's what my boss called them). It's basically a poorly manufactured string, or one that had degenerated, and was causing an out of tune harmonic with itself.
You might try a new set of strings, if you haven't already.
Eric
Eric Rudd
efrudd@gmail.com
For an engineering discography, please see www.allmusic.com
Eric Bridenbaker
« Reply #6 on: April 06, 2005, 09:46:00 am »
For sure, the intonation is the first place to check. This is done by comparing the 12th, or better still the 19th fret harmonic against the fretted note. They should be very close on a tuner, with light to moderate touch. If the guitar is in need of attention, you may wish to have a guitar tech setup the instrument.
Also, it is totally possible for a strong player to pull sharp as much as 25 to 30 cents, simply by pressing too hard. This effect is exaggerated by action that is too high and is more prominent on the lower frets.
If the player is a Zakk fan, he may even be pinching out unintentional harmonics, which subscribe to a just tuning scheme and may seem out from the equal tempered notes used by the other instruments in the recording.
Bad strings or even bad frets can throw the tuning off. Action that is too low can cause the string  to a catch a higher fret than intended, or even the pickup, which is bizarre sounding, but easy to identify at least...
Room nodes and higly notched/phased sounds can  do strange things to the perceived pitch as well.
If the player does dig in too hard there, then a temporary solution is tune specifically for the context of this note to get the take.
Cheers,
Eric
ALLEN WRENCH
« Reply #7 on: April 06, 2005, 10:15:01 am »
First of all I can intonate my guitars and basses myself.  But just to double check I had a friend of mine who is a ‘senior master-builder’ for Fender double check and the intonation’s fine, and the playing technique is fine.
Once again… this is not when one guitar is playing with another guitar, or when the guitar is playing with the bass, or even when the guitar is playing a chord…
When the guitar is playing a single not (such as just an open A)… the single note sounds out of tune with ‘itself’.
The terms ‘overtone’ and ‘wolf tone’ sound like what’s going on.  next thing I’m going to try is changing the strings and then also the brand of strings.
canada
« Reply #8 on: April 06, 2005, 10:16:55 am »
Eric Bridenbaker wrote on Wed, 06 April 2005 14:46
Haha, this is true.  Poor Zakk.
But yeah, this sounds like the classic "holy shit, I actually have to maintain my guitar even though I play metal, punk, reggae, hardcore, low-fi etc ?!"
you're not to be so blind with patriotism that you can't face reality. wrong is wrong, no matter who does it or says it  -       malcolm x
maxdimario
« Reply #9 on: April 06, 2005, 10:44:17 am »
What's probably happened is that the neck (or neck and middle)pickup is too close to the strings.
this causes the bass strings to create a second or 'false tone' due to the physical restriction of the pickup's magnet on the guitar string.
you need to pull the pickup(s) away from the strings, sacrificing sensibility, but the sound will improve.
PP
« Reply #10 on: April 06, 2005, 04:32:28 pm »
Level
« Reply #11 on: April 06, 2005, 04:37:03 pm »
Attack can certainly change intonation as well as decay. No one I know can pluck a string , have it resound and decay and stay within a few cents. The nature of the instruments!
Forget the tuning meter and twist on the machine heads to find what sounds good to you overall.
Try to stay away from other kinds of twisties  (like doobies) because they certainly have a tendancey to change the aural aspects of tuning!!!
http://balancedmastering.com
"Listen and Learn"
---Since 1975---
runamuck
« Reply #12 on: April 06, 2005, 06:57:32 pm »
I used to rebuild and tune pianos. I would ocassionally come across a string that had been nicked or kinked that exhibited the same characteristics you are describing, if I understand you correctly.
All to be done would be to replace it.
It could be that simple.
Jim
Bill Mueller
« Reply #13 on: April 06, 2005, 08:20:22 pm »
In addition to all the good advice concerning intonation, fresh strings and tuning, I want to point out that the electric guitar, like the piano or any instrument that uses tensioned metal strings exhibits a characteristic called inharmonisity that prevents it from being truly in tune in both it's fundamental and harmonic frequencies.
There is a tuning modification called the buzz feiten system that corrects for the problem in guitars. Once you have heard a guitar with this modification, I doubt you will ever want to go back.
http://www.buzzfeiten.com/
Best Regards,
Bill
"Don't take it personally. But this shit is a science." J.J.Blair
“The Internet is only a means of communication,” he wrote. “It is not an amorphous extraterrestrial body with an entitlement to norms that run counter to the fundamental principles of human rights. There is nothing in the criminal or civil law which legalizes that which is otherwise illegal simply because the transaction takes place over the Internet.” Irish judge, Peter Charleton
Level
« Reply #14 on: April 06, 2005, 08:29:28 pm »
Yea Bill, I got that done to my bass...no wonder I never have issues with it anymore.
If it works the guitar as well (and I am sure it does) it is a must install.
Hell, if Larry C says so...go for it.
"Listen and Learn"
---Since 1975---
