malice wrote on Wed, 06 April 2005 08:44 |
Dear Jerry,
jerry springer?
Quote: |
the reason I raised this problem is that I recently had the case with an MCI 2 track machine. As soon as the tape was reaching the end, the capstan couldn't tie the tape properly against the heads causing slight loss in hi frequencies...
weird. i've had similar problems with MCI decks that had horribly dirty capstans and pinch roller, but my problem was tape slipping and the machine going totally crazy.
Quote: |
a rather odd problem, but I did had this problem as I describe it to you.
i don't doubt you.
i've had MCI's do the weirdest things like, drop out of record in the middle of a punch and go to some random locate point and start playing.
i've had them:
- not punch in on tracks i have armed
- not toggle between live signal and recorded
- hit the stop button and have the deck go into rewind
- had it locate 1 second behind the forward 1 second ahead over and over but never stop on the actual locate point.
Quote: |
I'm not used to your place, it would be bad form from me to tell lies the first post I make
well, you are french.......................................
