klarkin wrote on Mon, 04 April 2005 03:38 |
I am having a very hard time discerning the differences between various converters and would like to know exactly what is the best way to do a comparison. HELP!!
Kenny
When trying to discern the difference between good converters, it's important to use high quality source material. Preferably something like a first generation analog recording of a real live acoustic source, such as a vocal group, grand piano, acoustic guitars, etc, with simple & accurate stereo micing that captures lots of transient details and real acoustic ambience.
Connect the analog source to one input of an A/B switch, and also connect it to the analog in of the converter. Now loop the dig out of the converter to the dig in, and connect the converters final analog out to the B input of the A/B switch. "A" is direct analog, "B" is the analog signal passed through the entire A/D-D/A chain of the converter.
Then, A/B each converter against the source, not against another converter. The most accurate converter will be the one that sounds most like the analog source, not the one that sounds subjectively 'better' than another converter.
Using this technique, watch for things like a sudden widening or narrowing of the stereo image when you switch from analog source to converter. This can indicate a shortcoming in the converter's ability to accurately reproduce transient detail that is necessary for accurate stereo imaging, among other things.
During 2002 & 2003, I performed this type of testing (among other duties) for a high end converter manufacturer on a weekly basis, and in my experience, this type of testing can be very revealing. These tests were performed using first gen analog master tapes, Spectral power amps, and Avalon speakers, which have very good imaging.
Of course, the test will be more revealing if you use speakers that are capable of accurately reproducing fine imaging details, but some folks can succesfully perform tests like this using somewhat less revealing speakers. It helps if you're familiar with the speaker.
We also discovered that when you use a high quality analog source and a revealing playback system, and compare the converter to the source, not another converter, even barely measureable differences can be quite audible when you hit the A/B switch. You don't have to be a golden ear to hear the difference. If there is anything wrong, most people can hear it.
