Yiannis wrote on Fri, 08 April 2005 23:04 |
Bob,
I have try to make Hedd MASTER and the 324 SLAVE. When I am doing that 324 is to word clock mode and under this situation I am changing the sample rate on the hedd and it changes at the 324 too. There is clocking... but noise too!!
When I have 324 MASTER and hedd SLAVE(WC mode) the sample rate switch on the hedd has no effect of course.
BTW here is my block diagram again Greedings Yiannis
OK, I looked at your block diagram. It is very basic, so should be easy to debug.
My first question is: When processing using the HEDD on D-D, where are you monitoring? Are you monitoring using the DAC in the MOTU? That's what you should be doing, though an external DAC would give you better sound, and I don't see an additional SPDIF or AES output in the MOTU that would serve you to feed an external DAC. What is the jack labelled "DAT" on the MOTU? Is that an additional SPDIF output?
My second suggestion is how to troubleshoot this:
Step one. Remove the wordclock connection from the input of the MOTU. Remove the SPDIF insert. Get the MOTU to function cleanly and sound good with no insert engaged and on its on INTERNAL clock, NOT wordclock. This is important for the debugging and if you insist on using the WC, wait till the last step to add this complication.
Step two. Take a SINGLE RCA to RCA cable and insert it between the SPDIF Aux Jacks of the MOTU. That is--- NO HEDD. I repeat: NO HEDD. Prove to yourself that the insert works, reliably and cleanly without the HEDD. Prove it insofar as when you pull that SINGLE cable out, you hear NO SOUND. And when you insert it, you do hear sound.
Step three: Replace that single cable with an SPDIF insert to and from the HEDD. Set the HEDD to Digital Position, 24 bit, SPDIF. Everything should work properly.
If it does not, either your HEDD is defective, a switch is set wrong (do you see signal on the HEDD's meters?), OR, and here's where it gets a bit dicey: You must speak to Dave Hill to get the details about the New HEDD mode where it becomes a master clock in some situations when processing digitally. I wouldn't want to have that mode UNLESS I could manually turn it off, because how else would you get it to work in the above scenario where the MOTU is the master clock and you are simply processing digitally with the HEDD as a slave. An external processor which is a slave should be replaceable and debuggable by using a single patch cord from In to OUT as described in Step two.
Let us know if this helps you fix your problem.
BK
