Yiannis wrote on Fri, 08 April 2005 06:04 |
bobkatz wrote on Thu, 07 April 2005 23:25 | Well the following new information changes everything:
By the way, guys, Dave Hill just told me today that a recent revision to the firmware of the HEDD has changed its configuration.
It is now possible to make it be the master clock even in a D-D situation, exactly as could the Finalizer. You have to set it to "24 bit", but this is just a mode switch in lieu of another label on the front panel. I'm not sure how you turn the mode on or off, to be honest as I do not have this revision nor do I need it.
Dave did it so that people could patch the HEDD in a digital insert without getting confused over clock loops or losing lock... I guess that would be people who do not have DAWs that can run internal clock, whoever that might be.
BK
Well what about my config Bob?
Is something wrong with it?
Greetings Yiannis
I'm sorry, Yiannis, I didn't have time to study your config... I'm hoping also that with the information that has been supplied in this thread, you personally will be able to study your config and determine if there is:
signal starts at a master clock, goes through a series of devices which are slaved, and reaches an end, is not broken by any other master clock.
But I must confess I did not look at your diagram... send me a private message with the URL of your diagram and I'll try to look at it. But the thing is with this new model of HEDD and its options that I am not familiar with, it could confuse the issue.
You need to determine if the HEDD is in a mode which is creating a master clock on its own. This is VERY easy to do. Just leave nothing on its input, and feed its output to, say, a DAT machine or anything else that can slave lock, and see if the slave is seeing a clock. It's that simple... you have to learn how to debug your system yourself.
