Thanks everyone for the input.
The original audio was recorded on Panasonic DVC pro 50 vtrs. It is then captured to to 16 bit 48k files in a Final Cut Pro system via SDI with embedded audio using a Decklink card. (
www.decklink.com). All that is out of my hands. (We also get material that originates on Betacam SP analog, also captured on a digibeta deck (reads the SP as well) via SDI with embedded audio)
I receive the audio as an OMF file. 16 bits 48k. I edit and mix and must deliver an SDII (or AIFF) file that is laid back to Digibeta via Final Cut Pro and a Decklink card, via SDI embedded audio.
I notice that final cut will accept 24 bit files but I don't know if it plays them natively or does some kind of conversion on the fly. We do need to make DA88s of the stems as well as a mix.
The system we work on is based on Digital Performer software, running on a macintosh computer. Digital Performer will run in either 16 or 24 bit mode.
Again thank you everyone for your comments. They are appreciated. If there is anything I have left out I would be happy to supply that information.
Bob thanks for the comments. Just got your book on mastering and am trying to plow through it.
Jason Levy
