Here's how I did it recently. Pretty basic but worked for me.
I bought or built one of each of these:
Belden 1266A Foil Shield
Belden 89207 Plenum (Teflon insulation and jacket)
BLUE Blueberry
Canare L-2T2S
Canare L-4E6S Quad
DiMarzio Braided Jacket
Gotham GAC-3
Gotham GAC-4 Quad
Gotham GAC-2AES 110 ohm AES
Mogami W2549
Mogami W2534 Quad
Mogami W3080 110 ohm AES
Planet Waves
All were 20 feet long. Connectors were XLR, and all were Neutrik silver except for Planet Waves and BLUE.
I connected each cable one at a time to a DA/AD loop using Lavry Blue 4496. I ran mono program material through this loop and recorded each track, then just did blind switching comparing A-B, A-C, A-D, etc. Then went to B-C, B-D, B-E, and so on until all combinations had been compared to each other. Basic comparisons, just listening for preferences using my own familiar recordings of various voices and styles, and some acoustic instruments. There was very little audible difference from this test, but I did pick general categories of "good" vs "not quite so good". To me, good = clarity and detail and full bass. Bad = soft and dull or harsh.
Next I connected a Y-splitter to a Sony C48 microphone running on battery power. I ran cable A and cable B to two matched channels of a Gordon preamp. Then each channel to the converter using a short piece of Belden 89207. Since I had already found there was not a huge difference in the line level signals, and the Belden had performed well, this seemed reasonable to me.
I sang and played and recorded both channels simultaneously. Then I played the samples back and again used blind A-B comparison to simply pick which I preferred. Whichever won was left connected, and the next candidate was plugged in to compete.
I repeated the same songs, and selected the choice from this next comparison. And so on.
After all that I had one clear winner: Belden 89207. It easily outperformed every other cable, for my preferences of open, strong tone.
I had picked four runners up, so I set those up in the rotating live comparisons and picked which I preferred from the batch. After I selected the best from this second round, I connected it back against the 89207 to make sure of my first opinion. I reversed the Y-connections and the preamp channels and tried again. The Belden again was by far the best.
I ranked these four alternates in this order:
1. Gotham GAC-2AES 110 ohm AES
2. Gotham GAC-3
3. Mogami W3080 110 ohm AES
4. Canare L-2T2S
These all had a pleasant sound, maybe a little mellow, but not too harsh or dull.
In my opinion none of the others were anything special, many sounded soft and cloudy, and the bass often seemed subdued with a slow attack.
So, a tedious routine, but I only had to do it this one time and now I know. Would the results be different if I didn't use the splitter, or if I used another mic, or different preamp, or...? I don't know, but the Belden was so obviously better than the others that I'd be surprised if there was a huge variation from using some different methods. I spent about $270 on the pre-made cables, mostly at Redco. They don't stock 89207 though, I got a bulk quantity of that from Anixter and assembled my own. Redco has an excellent realtime cable builder program that made it easy to order these combinations, and they did great fast work. I'll just sell these cables for a discount to someone else who might want to compare the differences.
I was hoping something besides the 89207 would win, because this is very tough, stiff, permanent installation cable that is difficult to work with. It's hard to prep and it doesn't coil well, and can pull microphones around in their mounts if not routed properly. But it is cheap and sounds great so that's what I'm using.
Steve
