SKIN EFFECT (in cables) By Dan Lavry
Copyright Lavry Engineering
(These are notes from my upcoming help section to be posted soon on my web. I am placing them here because they are educational.)
INTRODUCTIONThe term skin effect is not new to audio. Many speaker cable manufacturers have been “preying on the innocent” with suggestions that their cables sound better because of the skin effect.
Skin effect is real, but like most engineering issues, it begs for QUANTIFYING. The lack of quantifying opens the doors for out of place claims, such as skin effect in relation to speaker wires. On the other hand, the skin effect is an everyday term in other industries. It is an important factor where cable transmission of high frequency signals over some distance (both analog and digital).
Again, the skin effect issue begs for quantifying and the 3 major factors are:
Cable length, frequencies of operation and cable construction. I will be talking about all three in more detail later. I will start my presentation by showing what skin effect does to a digital signal, which is a part of digital audio today.
Digital signals “rise and fall quickly”, and there are many cases where the speed can be retained. There are other cases where the rise and fall degrade (slow down). The first question to ask is: do we have enough skin effect to impact the signal in a PRACTICAL SENSE? If the rise time before skin effect is 10nsec, and the skin effect is 1nsec the answer is no. If the rise time is 10nsec and the skin effect is 1000nsec it is a definitive yes.
The skin effect does much more than “just slowing the rise time”. We, in audio, have heard the back and forth argument and counter argument about speaker wire. One guy says “we have skin effect”, the other guy says “but only at high frequencies”. Unfortunately, most arguments seem to miss the biggest point which is: cable length is the biggest contributor of them all. But I will get to that later.
The impact of the skin effect is highly non linear, because a single step (or any digital waveform) contains a wide range of frequencies, not just a single sine wave. The wide spread notion that the skin effect causes the electrons to migrate towards the outer diameter of a wire should be modified. The low frequency part of the signal utilizes the whole wire, while the high frequency electrons concentrate on the skin.
We end up having a “voltage divider action” between the cable and the load termination, and that attenuation is higher for the higher frequency portion of the signal.
We first need to examine what a skin effect does to a digital wave form. For that, I will show the outcome due to a SINGLE STEP digital transition from low to high. The amplitude set to 1, rise time set to 0 (a theoretical driver with an instantaneous rise time).
See plot bellow:
The Red dotted line signal shows a somewhat theoretical driver signal taking 10nSec to go from 0 to 1 value. I included this signal for reference.
The Blue wave shows the effect of “very little” skin effect, when comparing to the red signal. It reaches 90% of the final value in about 1nsec, while the red signal is only at 10% of its final value.
The Black line shows more skin effect than the blue one. The skin effect impact is in the ball park of the Red signal. They both reach 80% of the final value at about 8nsec. The skin effect is going to have some effect on a 10nsec signal.
The purple line shows a lot more skin effect. It reaches its 50% value in about 46nsec. So much skin effect is a major bottle knack for signals with 10nsec rise.
There are 2 important point to realize, before I get into quantifying the signals.
A. The blue, black and purple signals are the SAME SHAPE. The difference is the time scale, but the shape is the same. (Stretching or contacting the X axis).
B. The shape is highly non linear, nor is it exponential. The physical electromagnetic behavior is expressed by the “error function” (the shape of the curve)
Let us look again at the black line. The signal rises to 50% relatively fast, and takes a lot of time to get up the rest of the way. The next post will focus on some interesting relationships in a more quantifiable way.
See next post
Dan Lavry
www.lavryengineering.com
