Homero wrote on Sun, 13 March 2005 14:57 |
I have a variation of the theme here. I have started to use a cheap M-Audio Firewire interface to speedy up some tasks related to SRC. That interface uses an ASIO driver and Digital Performer supports it.
My chain is:
M-Audio (internal sync) SPDIF out--->dCS 972 D/D (SRC UP-Sample)---->dCS 954 D/A----> analog processing...
I believe that the dCS 972 D/D at the middle of the chain is breaking the clock chain and feeding the D/A converter with a cleaner clock. Is that correct?
Well, first of all, I'm pretty darn skeptical about the concept of upsampling in front of what is already an oversampling DAC in the first place! DCS should and could build all of that into the DAC with a single filtering system instead of rooking you for thousands of thousands of unnecessary dollars. I've heard a possible "improvement" using the 972, but as far as I'm concerned, it is totally unnecessary if DCS did their homework and did it right.
Secondly, you are NEVER really "breaking" a clock chain unless the sample rate converter is an asynchronous model. But since the DCS 972 is a synchronous sample rate converter its output rate is slaved by a ratio to the input rate and to the input PLL of the 972. The answer to your question of stability of the clock on the output of the 972 depends strictly on the quality of the Phase locked loop on the input of the DCS 972. It can be good, it can be bad, it can improve the jitter issue or make it worse. But the 972 has a good reputation for a good PLL, so it is probably attenuating the jitter on its input to a good extent. That's what you really meant by saying "breaking the clock chain", all it really means is the DCS 972 is attenuating its input jitter. And once again, DCS is charging you for something they should do better within the DAC! The DAC itself should contain a super quality PLL and there is no technical reason, other than DCS's pocketbook, why an additional "jitter reduction unit" should ever be needed in front of the DAC. If it does perform better, it is because the DAC itself is not built well enough.
But there is an even better choice you are better off making if it is possible to do this patch. DCS is extremely flexible in its clocking options. I believe that the DCS DAC allows you an option where it is the master and that can drive the wordclock of the 972, which can possibly work backwards and drive the M-Audio on external sync. Investigate that option, it will make the DAC stable as a rock.
Then the A/D on the other side of the analog processing can be on internal sync if it is feeding an additional (independent) DAW, which would be your best case, a win-win situation, you are running internal clock for both converters. It would be your case anyway if you are running a different rate in the A/D.
But if you are feeding your A/D back into the same DAW, then your best choice is to put the a/D on internal sync, lock the M Audio to that, and then you are forced to lock the DAC to the M Audio with whatever help the 972 provides.
Hope this helps!
BK
