ZETTERSTROEM wrote on Sat, 22 January 2005 20:31 |
by the way.....
spent most of today listening to a pair of adam P11...
among other thing i listened to a thethe record (mind bomb) that i've had for 15 years....
the thing that amazed me the most was the opening track..... there's an acoustic hihat on it than i know is eq'ed a bit thin.... i've heard it on all sorts of speakers.... but on the adam's it sounded like an analog beatbox hihat (eg.cr78)!!!!!!!!!
that ribbon is soooooo wrong..... it sounds nowhere near what is put into it....
another problem was that vocals sounded like they were 2-band compressed.... almost like the timing of the hi frequencies was out of time with the mids..... spooky!!!
so all in all an entirely different interpretation of a record that i know and love...
First of all you are agreeing with me 100%!
Did you read the thread?
I mentioned how i first heard the Adams, and the "P" series was the first models I came across. I mentioned in the beginning of the thread that they make vocals sound several feet behind or recessed.
You cannot compare the "P" series with the S2.5A!
Even the S3A sounds different!
It is like saying GM sucks because you test drove a Pinto.
and Corvettes are therefore, slow cars.
Please read the beginning of the thread.
These artifacts of the cheaper "P" series are simply NOT what the S2.5A are all about.
Listen for yourself.
Also, if designed properly, ribbons are amazing tweeters, with little weight compared to regular cones, and frequency response up to 40 KHz [34 KHz @ -3dB].
What is your problem with ribbons? I studied them, and 20 years ago, the only problem was they too were fragile, for the amazing response they had. Technology has surpassed that obstacle, for quite a while now.
If they are high velocity, that is not a bad quality; it only means they must be properly aligned [physically and electronically]
There are no other problems in terms of phase, or distortion, or dispersion.
Just forget about the "P" series.
Also, the price range is not the same; with the price of S2.5As, you can buy three P11s.
Don't bother with this type of comparison.
