first off - thanks guys, this is fascinating for me - i appreciate the lesson.
trev - thanks so much for the kind words - i just want everything i do to go through you first so it makes me look better in the end to new clients!
a) in one song the sample is before the band kicks in, and i thought that should be easy as it seems it will be. however, in another song the samples serve as a vocal track (ie instrumental with wierdo samples). in my grasp of hopes i though this could simply be a limiting issue, and thought maybe if you set your threshold just above regular program material with a decently steep ratio and pulled these peaks down, that'd address our issue. my only concern was if that would adversely affect any settings from the other "ok" mixes (and by ok i mean, assuming we've addressed our hihat issue!)
it;s really trashy sounding punk with lots of room mic/overheads. the band wasnt the tightest, so i sorta downplayed that by emphazing the room mics. the whole thing was 14 songs, tracked, overdub, mix in 22 hrs. we're talking local band - self released here. fortunately the main guy respects my opinion and followed my advice to take it to trev for mastering. i can't wait to hear it on trev's fancy speakers. frequency wise top to bottom i think it's ok with the exception of the hat issue - maybe conservative on the low end - you know those B&Ws. i'm interested to hear trev's analysis. it's also the first mix done in a new room BTW.
b) awesome. and really, i think my attention to detail on this is wayyyyyyyyy deeper than the band. they're already totally stoked on everything, it's already far beyond thier expectations (good for me). i'm just not happy with my work. (quite common i assume)
jfingo - that's exactly what i was thinking - if i were remixing i think maybe i'd try and de-ess the hats in the overheads - but like you said - i'd be wary of what that did to the image. can you go into the reasoning of using MS de-essing vs regular stereo? my only experience w/MS is in tracking... so i guess, in effect are you saying your compression only affects the side signal - even though the source material is regular stereo, the method of de-essing is sort of a reverse processing? does this tend to leave your center image intact and only mess with the sides?
brad - i don't really have a problem with posting before/afters. trev?
thanks all for your input.
best,
nick
