Hello Barry,
sorry for my late reply, x-mas and some other obligations...
First the modification or better EM/RF removal of the UM92.1S
Gefell did the RFI/EMI protection with a crow bar, and traded the very high noise rejection for the overall sound.
The protection is a sum of four individual L/C protection and one simple C protection. I assigned numbers to those components that are not indicated in the standard Gefell diagram.
Position 1 and 10 is the HF protections to eliminate the risk of stray fields (EM/RF) interference in the remote pattern circuit. This protection does not change the sound directly and does not need to be removed.
Position 2 and 9 is the B+ protection, it does not change the sound and won't cause a problem if left in the circuit.
Position 3/7 and 4/8 need to be removed, this protection circuit chokes the high end and introduces phase shift, depending on program material, load down of the following mic pre, etc.
Position 5 (in some mics there is an additional cap to ground) is for HF filtering in the filament circuit, does not need to be removed.
Position 6 a cathode by pass to remove HF inductive stray field as the same times as it acts as a (audio) high frequency by pass, that makes the mic quite nasal.
In general I remove all those filters and rely on good microphone cable (Klaus pointed out the superior HF rejection of the historic EMT double reusen design, found in some modern cables), with proper grounding scheme in the power sup. and interfacing equipment.
To address the "presence" boost, it mainly depends on circuit tree design, and secondary on the head design (the plexi HF deflector intergraded in the capsule holder comes to mind).
However, by changing the circuit over to the blue drawn, alternative x-former hook up, you should be able to reduce this effect. Were and why it was installed is a question of design philosophy, both ways have advantage and disadvantages, enough discussion material for an entire new post.
To answer your question about the size of the x-former, it depends mostly on the core, and the new 92 x-former works better than the best historic 57 x-former.
To answer the last of your question,
both mics the VM1 and UM75 are good recording mics in their own ways, but in my findings the UM75 (with HF filter removed) is a more universal recording tool, great for main stream rock/pop and contemporary.
Were the standard VM1 is more a specialty mic, orchestra, scoring etc; the reason why I use the superior word is that the capsules of the UM75 is the perfection of simplicity of movable condensers, the VM1 capsule on the other hand has some acoustic "gadgetry" that trades of sound is some respects. Than again is a matter of perspective.
Disclaimer: ONLY QUALIFIED PEOPLE SHOULD ATTEMPT TO REMOVE THE CIRCUIT, IT WILL VOID YOUR MANUFACTURES WARRANTY AND WILL KILL YOU OR THE MIC IF YOU TRY IT ANYWAY WITHOUT PROPER TRAINING! Please do not forget, to break the connection to the 1.5K resistor if you use the alternative x-former hook up.
Hope that answers your question...
Best regards,
(Edited 7/21/09 by Webmaster to relink image)
