Eliott James wrote on Sun, 02 January 2005 03:08 |
In the clocking thread, Dan lavry wrote recently:
We are not about listening tests here.
That answers my question.
Leaving the listening tests aside, let me clarify it once again: An external clock WILL NOT, and CAN NOT reduce the jitter of an AD box operating in external clock mode!
When operating in external mode, the question is: How much more jitter will the external clock setup ADD TO the PLL circuit jitter. The external clock CAN NOT REDUCE THE JITTER OF THE AD PLL CIRCUIT.
So your proposed listening test is COMPARING APPLES TO ORANGES. You are comparing an AD operating with internal clock with it’s performance using external clock.
It is unlikely that an AD will have an internal clock worse than external clock driving a PLL. Unlikely, but possible.
When you find such a beast, assuming you want to keep it, don’t buy the complete BS story that some particular clock source has some magical properties to improve the AD clock. If one clock box will improve it, another clock box with about the same jitter will also improve it.
The statement regarding external clocks reduces jitter is flat out NOT TRUE. When anyone back paddle from a technical argument to a fuzzy statement “but it sounds better”, they are in fact saying that jitter can be good, which is as ridicules as a $500 wood knob for your solid gold speaker wires suspended in the air by young blond vegetarian acrobats…
Regards
Dan Lavry
